rtems-tester initial port getting "'NoneType' object is not iterable"
dufault at hda.com
dufault at hda.com
Sat Sep 21 13:48:16 UTC 2019
> On Sep 20, 2019, at 21:43 , Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Sep 20, 2019, 8:21 PM Chris Johns <chrisj at rtems.org> wrote:
> On 21/9/19 5:56 am, dufault at hda.com wrote:
> > One thing I should have said is that “rtems" and "rtems-tester" are the master branches, "rtems-tester" is updated as of yesterday, and “rtems” is recent.
> Thanks.
> >> On Sep 20, 2019, at 15:46 , Peter Dufault <dufault at hda.com> wrote:
> >> I’m bringing up the rtems-tester for the PowerPC “beatnik” bsp. I’m impressed with how easy it is to implement (well done, Chris).
> Thanks, it is good to get this type of feedback and things are just working.
> > But after doing all the easy work, and just as I thought my initial run of the “samples" was about to exit successfully, the script faulted and gave me the error "TypeError: 'NoneType' object is not iterable”. I’ve pasted the output of my run below.
> OK.
> >> Average test time: 0:00:40.583694
> Does this target take a bit of time to boot?
There’s at least 16 seconds overhead - 2 seconds in the power off / on, about 7 seconds before the MOTLOAD monitor visibly starts (probably testing), and a 7 second delay (that I now see I can change, I’ll lower it to 1) where it is letting you hit <ESC> to skip the auto-boot.
> >> Testing time : 0:09:28.171711
> >> Traceback (most recent call last):
> >> File "../rtems-tools/tester/rt/cmd-test.py", line 42, in <module>
> >> test.run(sys.argv[1:], command_path = base)
> >> File "/home/dufault/development/rtems/rtems-tools/tester/rt/test.py", line 455, in run
> >> for report_format in report_formats:
> This is from Kinsey patch where report formats was added....
> https://git.rtems.org/rtems-tools/commit/?id=5fcaf843bdb491e2da14dc1af61806ac6d20bae5
> Joel?
> Sorry I was traveling home today. I have good news to pass along later.
> I will get Kinsey to look at this. Peter can you email us the configuration file?
Here’s the global “.ini” file, rtems-tools/tester/rtems/testing/bsps/beatnik.ini. I notice I should change the reset expressikno to be any error status ("^Error Status: " is enough to indicate a problem).
# This is for the MVME5500 PowerPC VME board running the "beatnik" BSP.
# - The console is connected to a telnet tty device.
# - The system is running MOTLoad RTOS Version 2.0, PAL Version 2.5 RM01
# - The system is connected to ethernet and is booted via TFTP.
[beatnik]
bsp = beatnik
arch = powerpc
tester = %{_rtscripts}/tftp.cfg
jobs = 1
test_restarts = 3
target_reset_regex = ^Error Status: 00000081
target_start_regex = ^MVME5500>
requires = target_on_command, target_off_command, target_reset_command, bsp_tty_dev
Here’s my site “.ini” file.
- beatnik-mkbin is a shell script that does this: "powerpc-rtems5-objcopy -Obinary ${from} ${to}” to create a “.bin” from a “.exe”;
- power-ctl is a shell script that manipulates a network power switch;
- The console runs at 9600 baud and uses a raspberry PI named “swlab-term” running ser2net at port 2000.
[beatnik]
tftp_port = 3822
bsp_tty_dev = swlab-term:2000
target_pretest_command = ./beatnik-mkbin @EXE@
target_exe_filter = /\.exe/.bin/
target_on_command = ./power-ctl 1 off-on
target_off_command = ./power-ctl 1 off
target_reset_command = ./power-ctl 1 off-on
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
