Where are results of rtems-tester test results archived?
dufault at hda.com
dufault at hda.com
Sat Sep 21 15:18:34 UTC 2019
> On Sep 21, 2019, at 11:03 , Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Sep 21, 2019, 9:55 AM Peter Dufault <dufault at hda.com> wrote:
> I’ve searched but can’t find anywhere. I’d like to see the results of the tests on all architectures to compare to what I see on PowerPC-beatnik.
> There is a build@ mailing list and the archives are at https://lists.rtems.org/pipermail/build/
> There should be results from at least me for psim.
> You are encouraged to subscribe to the list and post results. Many boards have no results.
That doesn’t look like what I want. I’m looking for something like the following (a small snippet of my test run in progress) to see what failures are shared by what board support packages.
[141/597] p:128 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: telnetd01.exe
[142/597] p:129 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios.exe
[143/597] p:129 f:7 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios01.exe
[144/597] p:129 f:8 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios02.exe
[145/597] p:129 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios03.exe
[146/597] p:130 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios04.exe
[147/597] p:131 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios05.exe
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
