Where are results of rtems-tester test results archived?
Sat Sep 21 15:40:47 UTC 2019
On Sat, Sep 21, 2019, 10:18 AM <dufault at hda.com> wrote:
> > On Sep 21, 2019, at 11:03 , Joel Sherrill <joel at rtems.org> wrote:
> > On Sat, Sep 21, 2019, 9:55 AM Peter Dufault <dufault at hda.com> wrote:
> > I’ve searched but can’t find anywhere.  I’d like to see the results of
> the tests on all architectures to compare to what I see on PowerPC-beatnik.
> > There is a build@ mailing list and the archives are at
> https://lists.rtems.org/pipermail/build/
> > There should be results from at least me for psim.
> > You are encouraged to subscribe to the list and post results. Many
> boards have no results.
> That doesn’t look like what I want.  I’m looking for something like the
> following (a small snippet of my test run in progress) to see what failures
> are shared by what board support packages.
> [141/597] p:128 f:7   u:2   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: telnetd01.exe
> [142/597] p:129 f:7   u:2   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios.exe
> [143/597] p:129 f:7   u:3   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios01.exe
> [144/597] p:129 f:8   u:3   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios02.exe
> [145/597] p:129 f:9   u:3   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios03.exe
> [146/597] p:130 f:9   u:3   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios04.exe
> [147/597] p:131 f:9   u:3   e:0   I:0   B:3   t:0   i:0   W:0   |
> powerpc/beatnik: termios05.exe
Most are for tools builds. I have a script I run periodically which
includes tools and bsps. This is a psim results post:
https://lists.rtems.org/pipermail/build/2019-August/002973.html
It shows the failures but still doesn't show the in process view. Does that
help at all?
FWIW I haven't investigated the 15 failures on psim.
--joel
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols
> subject to interception and tampering.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190921/b629c910/attachment-0002.html>
