Where are results of rtems-tester test results archived?
Chris Johns
chrisj at rtems.org
Sat Sep 21 20:41:32 UTC 2019
On 22/9/19 1:18 am, dufault at hda.com wrote:
>> On Sep 21, 2019, at 11:03 , Joel Sherrill <joel at rtems.org> wrote:
>> On Sat, Sep 21, 2019, 9:55 AM Peter Dufault <dufault at hda.com> wrote:
>> I’ve searched but can’t find anywhere. I’d like to see the results of the tests on all architectures to compare to what I see on PowerPC-beatnik.
>> There is a build@ mailing list and the archives are at https://lists.rtems.org/pipermail/build/
>> There should be results from at least me for psim.
>> You are encouraged to subscribe to the list and post results. Many boards have no results.
> That doesn’t look like what I want. I’m looking for something like the following (a small snippet of my test run in progress) to see what failures are shared by what board support packages.
> [141/597] p:128 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: telnetd01.exe
> [142/597] p:129 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios.exe
> [143/597] p:129 f:7 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios01.exe
> [144/597] p:129 f:8 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios02.exe
> [145/597] p:129 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios03.exe
> [146/597] p:130 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios04.exe
> [147/597] p:131 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios05.exe
The --log option should place all the test results in a log. Is that what you want?
There are other options that let you log the console data as well. This is
disabled by default to make the log more compact.
