Where are results of rtems-tester test results archived?
dufault at hda.com
dufault at hda.com
Sat Sep 21 21:49:19 UTC 2019
> On Sep 21, 2019, at 16:41 , Chris Johns <chrisj at rtems.org> wrote:
> On 22/9/19 1:18 am, dufault at hda.com wrote:
>>> On Sep 21, 2019, at 11:03 , Joel Sherrill <joel at rtems.org> wrote:
>>> On Sat, Sep 21, 2019, 9:55 AM Peter Dufault <dufault at hda.com> wrote:
>>> I’ve searched but can’t find anywhere. I’d like to see the results of the tests on all architectures to compare to what I see on PowerPC-beatnik.
>>> There is a build@ mailing list and the archives are at https://lists.rtems.org/pipermail/build/
>>> There should be results from at least me for psim.
>>> You are encouraged to subscribe to the list and post results. Many boards have no results.
>> That doesn’t look like what I want. I’m looking for something like the following (a small snippet of my test run in progress) to see what failures are shared by what board support packages.
>> [141/597] p:128 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: telnetd01.exe
>> [142/597] p:129 f:7 u:2 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios.exe
>> [143/597] p:129 f:7 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios01.exe
>> [144/597] p:129 f:8 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios02.exe
>> [145/597] p:129 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios03.exe
>> [146/597] p:130 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios04.exe
>> [147/597] p:131 f:9 u:3 e:0 I:0 B:3 t:0 i:0 W:0 | powerpc/beatnik: termios05.exe
> The --log option should place all the test results in a log. Is that what you want?
> There are other options that let you log the console data as well. This is
> disabled by default to make the log more compact.
I want a collection of results for all tested BSPs so that I can compare what I’m seeing with “beatnik” with others.
I thought there was a collection of systems that went through automated tests, an RTEMS testing lab of sorts. Am I confused? I was ready to try to get an MVME5500 and whatever else was needed to the lab.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
