Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Sep 22 05:34:45 UTC 2019
( Please use the reply to all option to keep the conversation on the list )
On Sun, Sep 22, 2019 at 10:50 AM Niteesh <gsnb.gn at gmail.com> wrote:
> bsp: erc32
> arch: sparc
> Odd. It is expected to work in erc32 if your build is right. I don't have a
recent sparc build so I can't verify right now.
Let's wait for other people to join and help with the issue. :)
> On Sun, Sep 22, 2019 at 10:49 AM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Sun, Sep 22, 2019 at 10:35 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>> The problem actually occurred when I was trying to run the hello.exe
>>> with gdb.
>>> 1: *sparc-rtems5-gdb hello.exe*
>>> and inside gdb to set the target as simulator.
>>> 2: *tar sim*
>>> This is the expected sequence, what BSP are you using?
>>> (gdb) tar  sim
>>> Undefined target command: "sim".  Try "help target".
>>> While going through some stackoverflow posts I found that to target
>>> simulators --enable-sim has to given while building gdb, Is this the
>>> problem or am I missing something?
>>> On Sun, Sep 22, 2019 at 10:29 AM Vijay Kumar Banerjee <
>>>> On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>> I was following the quick-start guide from
>>>>> https://docs.rtems.org/branches/master/user/start/index.html
>>>>> I followed the exact steps but still couldn't get the hello world
>>>>> running. I face issues when running the GDB, when trying to set the
>>>>> target to simulator I get "undefined target cmd: sim",
>>>>> Is it an issue on my side or is something missing in the docs?
>>>> Hi Niteesh,
>>>> Usually, it is enough to post to any one of devel or users list.
>>>> Can you please post the exact command sequence that gave you the
>>>> error? You can copy the command output here if it's not long, or paste
>>>> it somewhere like a github gist and send the link here.
>>>> Best regards,
>>>> Vijay
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/4def7ecb/attachment-0002.html>
