Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Sep 22 07:00:33 UTC 2019
Hello,
I just checked that the built-in sis in gdb has been disabled in this
commit:
https://git.rtems.org/rtems-source-builder/commit/?id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828
Niteesh: This means that the command you should use is `sparc-rtems5-sis`.
Can you please post the link to the exact page where the `sparc-rtems5-gdb`
steps are mentioned with `tar sim`? I think this would need to be updated
and
you can propose a patch for this.
Best regards,
Vijay
On Sun, Sep 22, 2019 at 11:04 AM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> ( Please use the reply to all option to keep the conversation on the list )
> On Sun, Sep 22, 2019 at 10:50 AM Niteesh <gsnb.gn at gmail.com> wrote:
>> bsp: erc32
>> arch: sparc
>> Odd. It is expected to work in erc32 if your build is right. I don't have
> a
> recent sparc build so I can't verify right now.
> Let's wait for other people to join and help with the issue. :)
>> On Sun, Sep 22, 2019 at 10:49 AM Vijay Kumar Banerjee <
>>> On Sun, Sep 22, 2019 at 10:35 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>> The problem actually occurred when I was trying to run the hello.exe
>>>> with gdb.
>>>> 1: *sparc-rtems5-gdb hello.exe*
>>>> and inside gdb to set the target as simulator.
>>>> 2: *tar sim*
>>>> This is the expected sequence, what BSP are you using?
>>>> (gdb) tar sim
>>>> Undefined target command: "sim". Try "help target".
>>>> While going through some stackoverflow posts I found that to target
>>>> simulators --enable-sim has to given while building gdb, Is this the
>>>> problem or am I missing something?
>>>> On Sun, Sep 22, 2019 at 10:29 AM Vijay Kumar Banerjee <
>>>>> On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>> I was following the quick-start guide from
>>>>>> https://docs.rtems.org/branches/master/user/start/index.html
>>>>>> I followed the exact steps but still couldn't get the hello world
>>>>>> running. I face issues when running the GDB, when trying to set the
>>>>>> target to simulator I get "undefined target cmd: sim",
>>>>>> Is it an issue on my side or is something missing in the docs?
>>>>> Hi Niteesh,
>>>>> Usually, it is enough to post to any one of devel or users list.
>>>>> Can you please post the exact command sequence that gave you the
>>>>> error? You can copy the command output here if it's not long, or paste
>>>>> it somewhere like a github gist and send the link here.
>>>>> Best regards,
>>>>> Vijay
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/96d64855/attachment-0002.html>
