Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sun Sep 22 07:31:40 UTC 2019
On Sun, Sep 22, 2019 at 12:59 PM Niteesh <gsnb.gn at gmail.com> wrote:
> https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running
> I actually changed the rtems version from 4.11 to 5 in the command, there
> was no documentation about the change in version 5.
> This wiki page is a bit outdated and marked as "To be removed". You should
follow the latest docs quickstart guide:
https://docs.rtems.org/branches/master/user/start/index.html
> On Sun, Sep 22, 2019 at 12:30 PM Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> Hello,
>> I just checked that the built-in sis in gdb has been disabled in this
>> commit:
>> https://git.rtems.org/rtems-source-builder/commit/?id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828
>> Niteesh: This means that the command you should use is `sparc-rtems5-sis`.
>> Can you please post the link to the exact page where the
>> `sparc-rtems5-gdb`
>> steps are mentioned with `tar sim`? I think this would need to be updated
>> and
>> you can propose a patch for this.
>> Best regards,
>> Vijay
>> On Sun, Sep 22, 2019 at 11:04 AM Vijay Kumar Banerjee <
>>> ( Please use the reply to all option to keep the conversation on the
>>> list )
>>> On Sun, Sep 22, 2019 at 10:50 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>> bsp: erc32
>>>> arch: sparc
>>>> Odd. It is expected to work in erc32 if your build is right. I don't
>>> have a
>>> recent sparc build so I can't verify right now.
>>> Let's wait for other people to join and help with the issue. :)
>>>> On Sun, Sep 22, 2019 at 10:49 AM Vijay Kumar Banerjee <
>>>>> On Sun, Sep 22, 2019 at 10:35 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>> The problem actually occurred when I was trying to run the hello.exe
>>>>>> with gdb.
>>>>>> 1: *sparc-rtems5-gdb hello.exe*
>>>>>> and inside gdb to set the target as simulator.
>>>>>> 2: *tar sim*
>>>>>> This is the expected sequence, what BSP are you using?
>>>>>> (gdb) tar  sim
>>>>>> Undefined target command: "sim".  Try "help target".
>>>>>> While going through some stackoverflow posts I found that to target
>>>>>> simulators --enable-sim has to given while building gdb, Is this the
>>>>>> problem or am I missing something?
>>>>>> On Sun, Sep 22, 2019 at 10:29 AM Vijay Kumar Banerjee <
>>>>>>> On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>>>> I was following the quick-start guide from
>>>>>>>> I followed the exact steps but still couldn't get the hello world
>>>>>>>> running. I face issues when running the GDB, when trying to set the
>>>>>>>> target to simulator I get "undefined target cmd: sim",
>>>>>>>> Is it an issue on my side or is something missing in the docs?
>>>>>>> Hi Niteesh,
>>>>>>> Usually, it is enough to post to any one of devel or users list.
>>>>>>> Can you please post the exact command sequence that gave you the
>>>>>>> error? You can copy the command output here if it's not long, or
>>>>>>> paste
>>>>>>> it somewhere like a github gist and send the link here.
>>>>>>> Best regards,
>>>>>>> Vijay
>>>>>>>> _______________________________________________
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/a2011c9c/attachment-0002.html>
