Problem running sparc-rtems5-gdb
Niteesh
gsnb.gn at gmail.com
Sun Sep 22 07:29:05 UTC 2019
https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running
I actually changed the rtems version from 4.11 to 5 in the command, there
was no documentation about the change in version 5.
On Sun, Sep 22, 2019 at 12:30 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hello,
> I just checked that the built-in sis in gdb has been disabled in this
> commit:
> https://git.rtems.org/rtems-source-builder/commit/?id=abc540105d10ddc9cad7de3c7ac0a9aa209ac828
> Niteesh: This means that the command you should use is `sparc-rtems5-sis`.
> Can you please post the link to the exact page where the `sparc-rtems5-gdb`
> steps are mentioned with `tar sim`? I think this would need to be updated
> and
> you can propose a patch for this.
> Best regards,
> Vijay
> On Sun, Sep 22, 2019 at 11:04 AM Vijay Kumar Banerjee <
>> ( Please use the reply to all option to keep the conversation on the list
>> On Sun, Sep 22, 2019 at 10:50 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>> bsp: erc32
>>> arch: sparc
>>> Odd. It is expected to work in erc32 if your build is right. I don't
>> have a
>> recent sparc build so I can't verify right now.
>> Let's wait for other people to join and help with the issue. :)
>>> On Sun, Sep 22, 2019 at 10:49 AM Vijay Kumar Banerjee <
>>>> On Sun, Sep 22, 2019 at 10:35 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>> The problem actually occurred when I was trying to run the hello.exe
>>>>> with gdb.
>>>>> 1: *sparc-rtems5-gdb hello.exe*
>>>>> and inside gdb to set the target as simulator.
>>>>> 2: *tar sim*
>>>>> This is the expected sequence, what BSP are you using?
>>>>> (gdb) tar sim
>>>>> Undefined target command: "sim". Try "help target".
>>>>> While going through some stackoverflow posts I found that to target
>>>>> simulators --enable-sim has to given while building gdb, Is this the
>>>>> problem or am I missing something?
>>>>> On Sun, Sep 22, 2019 at 10:29 AM Vijay Kumar Banerjee <
>>>>>> On Sun, Sep 22, 2019 at 10:01 AM Niteesh <gsnb.gn at gmail.com> wrote:
>>>>>>> I was following the quick-start guide from
>>>>>>> https://docs.rtems.org/branches/master/user/start/index.html
>>>>>>> I followed the exact steps but still couldn't get the hello world
>>>>>>> running. I face issues when running the GDB, when trying to set the
>>>>>>> target to simulator I get "undefined target cmd: sim",
>>>>>>> Is it an issue on my side or is something missing in the docs?
>>>>>> Hi Niteesh,
>>>>>> Usually, it is enough to post to any one of devel or users list.
>>>>>> Can you please post the exact command sequence that gave you the
>>>>>> error? You can copy the command output here if it's not long, or paste
>>>>>> it somewhere like a github gist and send the link here.
>>>>>> Best regards,
>>>>>> Vijay
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190922/ed119fa3/attachment-0002.html>
