Problem running sparc-rtems5-gdb
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Sep 24 17:31:45 UTC 2019
On Tue, Sep 24, 2019 at 11:00 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Tue, Sep 24, 2019 at 8:42 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Sun, Sep 22, 2019 at 2:14 AM Vijay Kumar Banerjee
>> <vijaykumar9597 at gmail.com> wrote:
>> > On Sun, Sep 22, 2019, 1:22 PM Niteesh <gsnb.gn at gmail.com> wrote:
>> >> Sorry, for so many questions.
>> >> But I was actually following the latest quick start guide, but it is
>> lacking information on building and running applications, the last page on
>> quick start section was about testing the BSP. That's why I had to refer to
>> the old wiki section.
>> > The doc has been updated recently and I don't know if someone is
>> working on it or not. I see a todo section there, which probably is for
>> building and running apps.
>> >> how could I patch this?
>> > Everyone: Where to add the guide to build and run hello world in docs?
>> The User Manual Ch. 2 Quick Start is the right place.
> Thanks Gedare!
> Niteesh: Would you like to add the instructions to the docs? you will
> basically have
> to add the steps you followed to get your hello world running. :)
> to write the documentation:
> 1. git clone git://git.rtems.org/rtems-docs.git
> 2. follow the README.txt to build the docs
> 3. add a hello-world.rst under rtems-docs/user/start and write the content.
> Please don't hesitate to ask any question that you might have.
> Best regards,
> Vijay.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190924/71cfd2ad/attachment-0002.html>
