What opens stdout? printf() fails after rtems-tester printf() succeeds.
dufault at hda.com
dufault at hda.com
Wed Sep 25 11:50:57 UTC 2019
> On Sep 25, 2019, at 01:09 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello Peter,
> did you configure the console driver?
> https://docs.rtems.org/branches/master/c-user/configuring_a_system.html#configure-application-needs-console-driver
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
Yes, I did. Below is the configuration, it is very similar to some of the ones in the tests. I added the RTEMS_TEST_INITIAL_EXTENSION in order to get rtems_tester_printf() to work.
Unfortunately the way the BSP works it copies the downloaded binary to address 0, over-writing the work space for the ROM monitor, so I can't use the ROM monitor debugger to debug the start-up.
I'll locate where the console driver opens file descriptor 1 for "stdout", maybe that will give me a clue.
#include <bsp.h> /* for device driver prototypes */
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_UNIFIED_WORK_AREAS
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE (64 * 1024)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 256
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT _POSIX_Init
#define CONFIGURE_POSIX_INIT_THREAD_TABLE
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#include <rtems/confdefs.h>
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
