[PATCH v3] riscv: add freedom E310 Arty A7 bsp
Sebastian Huber
Mon Sep 30 06:33:22 UTC 2019
Hello Pragnesh Patel,
could you please use this license for new code:
https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause
It would be nice if you could use a coding style close to the existing
code in this BSP (only if you have time).
Please don't change the default values in configure.ac and do not assume
by default you build the BSP for the E310. You can add a BSP variant, e.g.
bsps/riscv/riscv/config/e310arty.cfg
In the BSP options macros you can use the BSP name to change the
defaults, see
c/src/lib/libbsp/powerpc/qoriq/configure.ac
The riscv_console_probe() iterates over all nodes of the device tree,
please add the support for your driver to this loop.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
