[PATCH v3] riscv: add freedom E310 Arty A7 bsp
Pragnesh Patel
pragnesh.patel at sifive.com
Mon Sep 30 07:48:49 UTC 2019
On Mon, Sep 30, 2019 at 12:03 PM Hesham Almatary
<hesham.almatary at cl.cam.ac.uk> wrote:
> Hi Pragnesh,
> That's a so much better refined patch, thanks! Please find my minor
> comments inlined below.
> After the patch gets merged, could you please add a new section about
> that BSP to the RISC-V chapter doc here [1]?
> [1] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
Ok, I will do that.
> On Fri, 27 Sep 2019 at 12:20, Pragnesh Patel <pragnesh.patel at sifive.com> wrote:
> > Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
> > Update #3785.
> > Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
> > Changes in v3:
> > - Remove bsps/riscv/frdme310arty/ directory and added support for
> > Freedom FE310 soc in common bsps/riscv/riscv/ directory
> > - Added #define RISCV_ENABLE_FRDME310ARTY_SUPPORT in configure.ac
> > to enable support for FE310
> > - Change the RISCV_RAM_REGION_SIZE to 256 MB for riscv
> > Changes in v2:
> > bsps/riscv/frdme310arty/btimer/btimer.c
> > - Remove the read_csr() function from btimer.c
> > - Remove CONFIG_BTIMER_RISCV_GET_MCYCLES macro to get time in
> > microseconds
> > bsps/riscv/frdme310arty/clock/clockdrv.c
> > bsps/riscv/riscv/clock/clockdrv.c
> > - Delete both files and Add bsps/riscv/shared/clock/clockdrv.c
> > - riscv_clock_get_timebase_frequency(): Get timebase-frequency from
> > cpus or cpu at 0 devicetree node because riscv uses "cpus" node and
> > frdme310arty uses "cpu at 0" node to look for timebase-frequency
> > - Remove rtems_counter_initialize_converter() and
> > rtems_timecounter_simple_install() functions
> > bsps/riscv/frdme310arty/include/bsp/riscv.h
> > - Remove unused frdme310arty_l2c_base;
> > bsps/riscv/frdme310arty/start/bsp_fatal_halt.c
> > bsps/riscv/riscv/start/bsp_fatal_halt.c
> > - Delete this file and Add bsps/riscv/shared/start/bsp_fatal_halt.c
> > bsps/riscv/frdme310arty/start/bspstart.c
> > - Remove unused function riscv_get_node_byname()
> > bsps/riscv/frdme310arty/start/linkcmds.in
> > - Use @RISCV_RAM_REGION_BEGIN@ and @RISCV_RAM_REGION_SIZE@ instead of
> > hard coded values
> > c/src/lib/libbsp/riscv/frdme310arty/Makefile.am
> > - librtemsbsp_a_SOURCES -> bsps/riscv/shared/start/bsp_fatal_halt.c
> > - librtemsbsp_a_SOURCES -> bsps/riscv/shared/clock/clockdrv.c
> > c/src/lib/libbsp/riscv/frdme310arty/configure.ac
> > - change RISCV_RAM_REGION_SIZE to default 256MiB
> > bsps/riscv/riscv/irq/irq.c
> > - Delete this irq.c and it will now use bsps/riscv/shared/irq/irq.c
> > c/src/lib/libbsp/riscv/riscv/Makefile.am
> > - librtemsbsp_a_SOURCES -> bsps/riscv/shared/irq/irq.c
> > bsps/include/bsp/fatal.h | 3 +-
> > bsps/riscv/riscv/clock/clockdrv.c | 16 ++--
> > bsps/riscv/riscv/console/console-config.c | 57 +++++++++++++
> > bsps/riscv/riscv/console/fe310-uart.c | 100 +++++++++++++++++++++++
> > bsps/riscv/riscv/dts/frdme310arty.dts | 130 ++++++++++++++++++++++++++++++
> > bsps/riscv/riscv/include/bsp/fe310-uart.h | 42 ++++++++++
> > bsps/riscv/riscv/include/bsp/riscv.h | 4 +
> > bsps/riscv/riscv/start/bspstart.c | 52 ++++++++++++
> > c/src/lib/libbsp/riscv/riscv/Makefile.am | 8 ++
> > c/src/lib/libbsp/riscv/riscv/configure.ac | 7 +-
> > 10 files changed, 411 insertions(+), 8 deletions(-)
> > create mode 100644 bsps/riscv/riscv/console/fe310-uart.c
> > create mode 100644 bsps/riscv/riscv/dts/frdme310arty.dts
> Why do you need to add the .dts file? Is it just for reference?
> Doesn't the bootrom and/or u-boot pass its to RTEMS in a1 register?
We are using a custom Bootloader (Not bootrom or u-boot) for Freedom
E310. I will provide a link for it in
README. Bootloader will pass .dtb address in a1 register and copy the
rtems Binary from Flash to RAM and passes
control to RTEMS binary.
User can create a .dtb file which will be used by bootloader. Right
now, .dts file used for both as a reference and to generate
a .dtb file.
> > create mode 100644 bsps/riscv/riscv/include/bsp/fe310-uart.h
> > diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
> > index fae5461..3f8e1eb 100644
> > --- a/bsps/include/bsp/fatal.h
> > +++ b/bsps/include/bsp/fatal.h
> > @@ -152,7 +152,8 @@ typedef enum {
> > RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
> > RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
> > RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
> > - RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE
> > + RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
> > + RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
> > } bsp_fatal_code;
> > RTEMS_NO_RETURN static inline void
> > diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
> > index 7e6034d..7f32dcf 100644
> > --- a/bsps/riscv/riscv/clock/clockdrv.c
> > +++ b/bsps/riscv/riscv/clock/clockdrv.c
> > @@ -130,15 +130,21 @@ static uint32_t riscv_clock_get_timecount(struct timecounter *base)
> > static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
> > int node;
> > - const uint32_t *val;
> > - int len;
> > + fdt32_t *val;
> Any reason why did you get rid of the const?
That's due to the copy from previous patch v2, i will revert it back to const.
> > + int len=0;
> > node = fdt_path_offset(fdt, "/cpus");
> > - val = fdt_getprop(fdt, node, "timebase-frequency", &len);
> > + val = (fdt32_t *) fdt_getprop(fdt, node, "timebase-frequency", &len);
> > if (val == NULL || len < 4) {
> > - bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> > + int cpu0 = fdt_subnode_offset(fdt, node, "cpu at 0");
> > + val = (fdt32_t *) fdt_getprop(fdt, cpu0, "timebase-frequency", &len);
> > + if (val == NULL || len < 4) {
> > + bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> > return fdt32_to_cpu(*val);
> > diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> > index 464b4b0..8a3472d 100644
> > --- a/bsps/riscv/riscv/console/console-config.c
> > +++ b/bsps/riscv/riscv/console/console-config.c
> > @@ -28,6 +28,11 @@
> > #include <libfdt.h>
> > #include <string.h>
> > +#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
> > +#include <bsp/fe310-uart.h>
> > +fe310_uart_context driver_context;
> > +#endif
> > #if RISCV_ENABLE_HTIF_SUPPORT != 0
> > static htif_console_context htif_console_instance;
> > #endif
> > @@ -59,7 +64,18 @@ static int riscv_get_console_node(const void *fdt)
> > stdout_path = "";
> > +#if RISCV_ENABLE_FRDME310ARTY_SUPPORT > 0
> Could you please be consistent with this and write it all over the patch as:
Ok, will update this in v4.
> > + int root;
> > + int soc;
> > + root = fdt_path_offset(fdt, "/");
> > + soc = fdt_subnode_offset(fdt, root, "soc");
> > + int offset=fdt_subnode_offset(fdt, soc,stdout_path);
> > + return offset;
> > +#else
> > return fdt_path_offset(fdt, stdout_path);
> > +#endif
> > #if RISCV_CONSOLE_MAX_NS16550_DEVICES > 0
> > @@ -193,6 +209,27 @@ static void riscv_console_probe(void)
> > #endif
> > + if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "sifive,uart0")) {
> > + fe310_uart_context *ctx ;
> > + ctx=&driver_context;
> > + ctx->regs = (uintptr_t) riscv_fdt_get_address(fdt, node);
> > + if (ctx->regs == 0)
> > + bsp_fatal(RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE);
> > + if (node == console_node) {
> > + riscv_console.context = &ctx->base;
> > + riscv_console.putchar = fe310_console_putchar;
> > + riscv_console.getchar = fe310_uart_read;
> > + rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
> > +#endif
> > node = fdt_next_node(fdt, node, NULL);
> > @@ -224,6 +261,10 @@ rtems_status_code console_initialize(
> > size_t i;
> > #endif
> > + char path[] = "/dev/ttyS0";
> > +#endif
> > rtems_termios_initialize();
> > @@ -255,6 +296,22 @@ rtems_status_code console_initialize(
> > #endif
> > + fe310_uart_context * ctx = &driver_context;
> > + rtems_termios_device_install(
> > + path,
> > + &fe310_uart_handler,
> > + NULL,
> > + &ctx->base
> > + if (&ctx->base == riscv_console.context) {
> > + link(path, CONSOLE_DEVICE_NAME);
> > +#endif
> > return RTEMS_SUCCESSFUL;
> > diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
> > new file mode 100644
> > index 0000000..06b312f
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/console/fe310-uart.c
> > @@ -0,0 +1,100 @@
> > + * Copyright (c) 2019 Sachin Ghadi <sachin.ghadi at sifive.com>
> > + * Copyright (c) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.org/license/LICENSE.
> > +#include <bsp/riscv.h>
> > +#include <assert.h>
> > +static void irq_handler(void *arg)
> > + /*TODO*/
> > +int fe310_uart_read(rtems_termios_device_context *base)
> > + fe310_uart_context * ctx = (fe310_uart_context*) base;
> > + size_t i;
> > + if (((ctx->regs->rxdata) & TXRXREADY) != 0) {
> > + return -1;
> > + } else {
> > + return ctx->regs->rxdata;
> > +static ssize_t fe310_uart_write (
> > + rtems_termios_device_context *base,
> > + const char *buf,
> > + size_t n
> > + size_t i;
> > + rtems_status_code sc;
> > + (ctx->regs)->div = riscv_get_core_frequency()/ 115200 - 1;
> > + (ctx->regs)->txctrl |= 1;
> > + (ctx->regs)->rxctrl |= 1;
> > + for (i = 0; i < n; ++i) {
> > + while (((ctx->regs->txdata) & TXRXREADY) != 0) {
> > + ctx->regs->txdata = buf[i];
> > + return n;
> > +void fe310_console_putchar(rtems_termios_device_context * context,char c)
> > + fe310_uart_write ( context, &c,1);
> > +void console_context_init(
> > + int device_tree_node
> > + /*TODO*/
> > +static bool fe310_uart_first_open (
> > + rtems_termios_tty *tty,
> > + struct termios *term,
> > + rtems_libio_open_close_args_t *args
> > + fe310_uart_context * ctx;
> > + /* Configure GPIO to be UART */
> > + sc = rtems_termios_set_initial_baud (tty, B115200);
> > + if ( sc != RTEMS_SUCCESSFUL ) {
> > + return false;
> > + /* Set up a baud rate and enable tx and rx */
> > + ctx = (fe310_uart_context *) base;
> > + return true;
> > +const rtems_termios_device_handler fe310_uart_handler = {
> > + .first_open = fe310_uart_first_open,
> > + .write = fe310_uart_write,
> > + .poll_read = fe310_uart_read,
> > + .mode = TERMIOS_POLLED
> > diff --git a/bsps/riscv/riscv/dts/frdme310arty.dts b/bsps/riscv/riscv/dts/frdme310arty.dts
> > index 0000000..a7a216d
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/dts/frdme310arty.dts
> > @@ -0,0 +1,130 @@
> > +/dts-v1/;
> > + #address-cells = <1>;
> > + #size-cells = <1>;
> > + compatible = "SiFive,FE310G-dev", "fe310-dev", "sifive-dev";
> > + model = "SiFive,FE310G";
> > + L20: chosen {
> > + stdout-path = "serial at 20000000";
> > + L17: cpus {
> > + #size-cells = <0>;
> > + L6: cpu at 0 {
> > + clocks = <&refclk>;
> > + compatible = "sifive,rocket0", "riscv";
> > + device_type = "cpu";
> > + i-cache-block-size = <64>;
> > + i-cache-sets = <128>;
> > + i-cache-size = <16384>;
> > + next-level-cache = <&L12>;
> > + reg = <0>;
> > + riscv,isa = "rv32imac";
> > + sifive,dtim = <&L5>;
> > + sifive,itim = <&L4>;
> > + status = "okay";
> > + timebase-frequency = <1000000>;
> > + L3: interrupt-controller {
> > + #interrupt-cells = <1>;
> > + compatible = "riscv,cpu-intc";
> > + interrupt-controller;
> > + L16: soc {
> > + compatible = "SiFive,FE310G-soc", "fe310-soc", "sifive-soc", "simple-bus";
> > + ranges;
> > + L19: tlclk {
> > + #clock-cells = <0>;
> > + clock-frequency = <32500000>;
> > + clock-output-names = "tlclk";
> > + compatible = "fixed-clock";
> > + refclk: refclk {
> > + clock-frequency = <66666666>;
> > + clock-output-names = "refclk";
> > + L1: clint at 2000000 {
> > + compatible = "riscv,clint0";
> > + interrupts-extended = <&L3 3 &L3 7>;
> > + reg = <0x2000000 0x10000>;
> > + reg-names = "control";
> > + L2: debug-controller at 0 {
> > + compatible = "sifive,debug-013", "riscv,debug-013";
> > + interrupts-extended = <&L3 65535>;
> > + reg = <0x0 0x1000>;
> > + L5: dtim at 80000000 {
> > + compatible = "sifive,dtim0";
> > + reg = <0x80000000 0x10000>;
> > + reg-names = "mem";
> > + L8: error-device at 3000 {
> > + compatible = "sifive,error0";
> > + reg = <0x3000 0x1000>;
> > + L9: global-external-interrupts {
> > + interrupt-parent = <&L0>;
> > + interrupts = <1 2 3 4>;
> > + L13: gpio at 20002000 {
> > + compatible = "sifive,gpio0";
> > + interrupts = <7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22>;
> > + reg = <0x20002000 0x1000>;
> > + L0: interrupt-controller at c000000 {
> > + compatible = "riscv,plic0";
> > + interrupts-extended = <&L3 11>;
> > + reg = <0xc000000 0x4000000>;
> > + riscv,max-priority = <7>;
> > + riscv,ndev = <26>;
> > + L4: itim at 8000000 {
> > + compatible = "sifive,itim0";
> > + reg = <0x8000000 0x4000>;
> > + L10: local-external-interrupts-0 {
> > + interrupt-parent = <&L3>;
> > + interrupts = <16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31>;
> > + L14: pwm at 20005000 {
> > + compatible = "sifive,pwm0";
> > + interrupts = <23 24 25 26>;
> > + reg = <0x20005000 0x1000>;
> > + L11: serial at 20000000 {
> > + compatible = "sifive,uart0";
> > + interrupts = <5>;
> > + reg = <0x20000000 0x1000>;
> > + L12: spi at 20004000 {
> > + compatible = "sifive,spi0";
> > + interrupts = <6>;
> > + reg = <0x20004000 0x1000 0x40000000 0x20000000>;
> > + reg-names = "control", "mem";
> > + L7: teststatus at 4000 {
> > + compatible = "sifive,test0";
> > + reg = <0x4000 0x1000>;
> > diff --git a/bsps/riscv/riscv/include/bsp/fe310-uart.h b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> > index 0000000..065e12a
> > --- /dev/null
> > +++ b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> > @@ -0,0 +1,42 @@
> > +#ifndef FE310_UART_H
> > +#define FE310_UART_H
> > +#define TXRXREADY (1 << 31)
> > +#include <rtems/termiostypes.h>
> > +#include <rtems/irq.h>
> > +typedef struct {
> > + uint32_t txdata;
> > + uint32_t rxdata;
> > + uint32_t txctrl;
> > + uint32_t rxctrl;
> > + uint32_t ie;
> > + uint32_t ip;
> > + uint32_t div;
> > +} fe310_uart_t;
> > +/* Low-level driver specific data structure */
> > +typedef struct {
> > + rtems_termios_device_context base;
> > + const char *device_name;
> > + volatile fe310_uart_t *regs;
> > +} fe310_uart_context;
> > +int fe310_uart_read(rtems_termios_device_context *base);
> > +void fe310_console_putchar(rtems_termios_device_context * context,char c);
> > +extern const rtems_termios_device_handler fe310_uart_handler;
> > +extern fe310_uart_context driver_context;
> > +#endif /* FE310_UART_H */
> > diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
> > index 374d5f7..f2f1a59 100644
> > --- a/bsps/riscv/riscv/include/bsp/riscv.h
> > +++ b/bsps/riscv/riscv/include/bsp/riscv.h
> > @@ -38,6 +38,10 @@ extern volatile RISCV_CLINT_regs *riscv_clint;
> > void *riscv_fdt_get_address(const void *fdt, int node);
> > +uint32_t riscv_get_core_frequency(void);
> > +#endif
> > #ifdef RTEMS_SMP
> > extern uint32_t riscv_hart_count;
> > #else
> > diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
> > index d4c4e1f..b3b33b5 100644
> > --- a/bsps/riscv/riscv/start/bspstart.c
> > +++ b/bsps/riscv/riscv/start/bspstart.c
> > @@ -30,6 +30,11 @@
> > #include <libfdt.h>
> > +#include <string.h>
> > +unsigned int riscv_core_freq;
> > +#endif
> > @@ -161,8 +166,55 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle)
> > return UINT32_MAX;
> > +static uint32_t get_core_frequency(void)
> > + uint32_t node;
> > + const char *fdt=bsp_fdt_get();
> > + char *tlclk;
> > + uint32_t len;
> > + do
> > + node=fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
> > + uint32_t *val=NULL;
> > + if(node>0)
> Spaces?
> > + tlclk = fdt_getprop(fdt, node, "clock-output-names", &len);
> > + if (strcmp(tlclk,"tlclk") == 0)
> > + val = fdt_getprop(fdt, node, "clock-frequency", &len);
> > + if(val !=NULL)
> > + riscv_core_freq=fdt32_to_cpu(*val);
> > + break;
> > + }else
> > + bsp_fatal(RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE);
> > + } while (node > 0);
> > + return riscv_core_freq;
> > +inline uint32_t riscv_get_core_frequency(void)
> > +#endif
> > void bsp_start(void)
> > riscv_find_harts();
> > bsp_interrupt_initialize();
> > + riscv_core_freq=get_core_frequency();
> > +#endif
> > diff --git a/c/src/lib/libbsp/riscv/riscv/Makefile.am b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > index 34bedf8..15b0865 100644
> > --- a/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > +++ b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> > @@ -46,7 +46,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
> > librtemsbsp_a_SOURCES +=../../../../../../bsps/riscv/riscv/clock/clockdrv.c
> > # Timer
> > +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
> > +#else
> > librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
> > +#endif
> > # IRQ
> > librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
> > @@ -60,6 +64,10 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
> > librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/console-config.c
> > librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/htif.c
> > +librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/fe310-uart.c
> > +#endif
> > if HAS_SMP
> > librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/start/bspsmp.c
> > endif
> > diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
> > index b01dee2..e6473ccd 100644
> > --- a/c/src/lib/libbsp/riscv/riscv/configure.ac
> > +++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
> > @@ -36,9 +36,12 @@ RTEMS_BSPOPTS_HELP([RISCV_MAXIMUM_EXTERNAL_INTERRUPTS],[maximum number of extern
> > RTEMS_BSPOPTS_SET([RISCV_ENABLE_HTIF_SUPPORT],[*],[])
> > RTEMS_BSPOPTS_HELP([RISCV_ENABLE_HTIF_SUPPORT],[enables the HTIF support if defined to a non-zero value, otherwise it is disabled (disabled by default)])
> > -RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[2])
> > +RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[])
> Can you please leave this as 2 as our default QEMU platform relies on it?
> > RTEMS_BSPOPTS_HELP([RISCV_CONSOLE_MAX_NS16550_DEVICES],[maximum number of NS16550 devices supported by the console driver (2 by default)])
> > +RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[*],[1])
> This needs to be [] to be disabled by default.
> > +RTEMS_BSPOPTS_HELP([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)])
> > RTEMS_BSP_CLEANUP_OPTIONS
> > case "${RTEMS_BSP}" in
> > @@ -59,7 +62,7 @@ AC_ARG_VAR([$1],[$2])dnl
> > RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
> > -RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 64MiB)],[0x04000000])
> > +RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 256MiB)],[0x10000000])
> Is there a good reason to change the memory size to 256MiB? Does
> Freedom have this amount of memory? Do any tests/applications fail
> with only 64MiB and not 256MiB?
Freedom E310 Arty A7 supports 256 MB RAM. i haven't tested with 64 MB RAM.
I will add a new frdme310arty.cfg file for the same.
> > AC_CONFIG_FILES([
> > Makefile
> > 2.7.4
> > devel mailing list
> > devel at rtems.org
