[PATCH] eng: Add Software Requirements Engineering chapter
Sebastian Huber
Mon Sep 30 13:09:11 UTC 2019
On 24/07/2019 15:44, Sebastian Huber wrote:
> +Requirement Traceability
> +The standard |E10-06| demands that requirements shall be under configuration
> +management, backwards-traceable and forward-traceable.
> +History of Requirements
> +The RTEMS requirements should placed in the RTEMS sources using Git for version
> +control. The history of requirements can be traced with Git. Special commit
> +procedures for changes in requirement files should be established. For
> +example, it should be allowed to change only one requirement per commit. A
> +dedicated Git commit message format may be used as well, e.g. use of
> +``Approved-by:`` or ``Reviewed-by:`` lines which indicate an agreed statement
> +(similar to the
> +`Linux kernel patch submission guidelines<https://www.kernel.org/doc/html/latest//process/submitting-patches.html#using-reported-by-tested-by-reviewed-by-suggested-by-and-fixes>`_).
In the first version of this patch, the proposal was to use Git to track
the history of specification items (requirements are a specialization
them). I think it would be better to add the revision and the
description of a change directly to the files, e.g. add a custom
attribute "changes" which contains a list of "revision" and
"description" tuples. Revision 1 items do not need this attribute.
Example:
changes:
- description: The description of the change from revision 1 (initial) to 2.
revision: 2
- description: The description of the change from revision 2 to 3.
revision: 3
- description: The description of the change from revision 3 to 4.
revision: 4
This information can be used to add the change log of each specification
item to a human readable document for example. The documentation
generator program does not need a Git repository in this case to extract
the information.
Also this way the revision of a specification item is independent of the
current version control system. This makes it easier to reference items
of a specific revision. For example: "With ABC-001 in revision 1 we
could meet our system requirements, however the change to revision 2 is
a problem, due to ...".
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
