[PATCH 1/2] c-user: Clarify config options use
Sebastian Huber
Wed Apr 1 07:03:40 UTC 2020
c-user/config/general.rst | 5 ++++-
c-user/config/mpci.rst | 24 ++++++++++++++++++++----
c-user/config/posix-api.rst | 10 ++++++++++
3 files changed, 34 insertions(+), 5 deletions(-)
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 388a8bf..c366be3 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -375,9 +375,12 @@ DESCRIPTION:
NOTES:
If there are more processors available than configured, the rest will be
- ignored. In uniprocessor configuration, this configuration define is
ignored.
+ This configuration option is only evaluated in SMP configurations (e.g. RTEMS
+ was built with the ``--enable-smp`` build configuration option). In all
+ other configurations it has no effect.
.. index:: CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
.. index:: maximum thread name size
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index a3b5e23..854600b 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -36,8 +36,10 @@ DESCRIPTION:
options are assumed to be provided.
NOTES:
- This has no impact unless RTEMS was built with the
- ``--enable-multiprocessing`` build configuration option.
+ This configuration option shall be undefined if the multiprocessing support
+ is not enabled (e.g. RTEMS was built without the ``--enable-multiprocessing``
+ build configuration option). Otherwise a compile time error in the
+ configuration file will occur.
.. index:: CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
@@ -73,7 +75,8 @@ DESCRIPTION:
:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE`.
NOTES:
- None.
+ This configuration option is only evaluated if
+ :ref:`CONFIGURE_MP_APPLICATION` is defined.
.. index:: CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
@@ -103,6 +106,9 @@ NOTES:
This value corresponds to the total number of objects which can be created
with the ``RTEMS_GLOBAL`` attribute.
.. index:: CONFIGURE_MP_MAXIMUM_NODES
.. _CONFIGURE_MP_MAXIMUM_NODES:
@@ -128,7 +134,8 @@ DESCRIPTION:
a multiprocessor system.
NOTES:
- None.
.. index:: CONFIGURE_MP_MAXIMUM_PROXIES
@@ -161,6 +168,9 @@ NOTES:
remote tasks/threads which can be blocked on objects on this node, see
:ref:`MPCIProxies`.
.. index:: CONFIGURE_MP_MPCI_TABLE_POINTER
.. _CONFIGURE_MP_MPCI_TABLE_POINTER:
@@ -190,6 +200,9 @@ NOTES:
Multiprocessor System assuming the BSP provides the proper set of
supporting methods.
.. index:: CONFIGURE_MP_NODE_NUMBER
.. _CONFIGURE_MP_NODE_NUMBER:
@@ -219,3 +232,6 @@ NOTES:
the Makefile variable ``NODE_NUMBER``. The same code is compiled with the
``NODE_NUMBER`` set to different values. The test programs behave
differently based upon their node number.
diff --git a/c-user/config/posix-api.rst b/c-user/config/posix-api.rst
index 0c84012..1359909 100644
--- a/c-user/config/posix-api.rst
+++ b/c-user/config/posix-api.rst
@@ -176,6 +176,11 @@ VALUE CONSTRAINTS:
RTEMS Workspace size calculation carried out by ``<rtems/confdefs.h>`` does
not overflow an integer of type ``uintptr_t``.
+ * It shall be zero if the POSIX API is not
+ enabled (e.g. RTEMS was built without the ``--enable-posix`` build
+ configuration option). Otherwise a compile time error in the configuration
+ file will occur.
DESCRIPTION:
The value of this configuration option defines the maximum number of POSIX
API Queued Signals that can be concurrently active.
@@ -366,6 +371,11 @@ VALUE CONSTRAINTS:
object class, if the value passed to :c:func:`rtems_resource_unlimited`
satisfies all other constraints of this configuration option.
+ file will occur.
DESCRIPTION:
API Timers that can be concurrently active.
2.16.4
