[PATCH 2/2] c-user: Move CONFIGURE_MAXIMUM_PRIORITY
Wed Apr 1 07:03:41 UTC 2020
Move this option to the scheduler configuration options.
 c-user/config/general.rst           | 58 -------------------------------------
 c-user/config/scheduler-general.rst | 58 +++++++++++++++++++++++++++++++++++++
 2 files changed, 58 insertions(+), 58 deletions(-)
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index c366be3..b1bca61 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -288,64 +288,6 @@ NOTES:
     The default value of three file descriptors allows RTEMS to support standard
     input, output, and error I/O streams on ``/dev/console``.
-.. index:: CONFIGURE_MAXIMUM_PRIORITY
-.. index:: maximum priority
-.. index:: number of priority levels
-.. _CONFIGURE_MAXIMUM_PRIORITY:
-CONFIGURE_MAXIMUM_PRIORITY
-CONSTANT:
-    ``CONFIGURE_MAXIMUM_PRIORITY``
-OPTION TYPE:
-    This configuration option is an integer define.
-DEFAULT VALUE:
-    The default value is 255.
-VALUE CONSTRAINTS:
-    The value of this configuration option shall be
-    an element of {3, 7, 31, 63, 127, 255}.
-DESCRIPTION:
-    For the following schedulers
-    * :ref:`SchedulerPriority`, which is the default in uniprocessor
-      configurations and can be configured through the
-      :ref:`CONFIGURE_SCHEDULER_PRIORITY` configuration option,
-    * :ref:`SchedulerSMPPriority` which can be configured through the
-      :ref:`CONFIGURE_SCHEDULER_PRIORITY_SMP` configuration option, and
-    * :ref:`SchedulerSMPPriorityAffinity` which can be configured through the
-      :ref:`CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP` configuration option
-    this configuration option specifies the maximum numeric priority of any task
-    for these schedulers and one less that the number of priority levels for
-    these schedulers.  For all other schedulers provided by RTEMS, this
-    configuration option has no effect.
-NOTES:
-    The numerically greatest priority is the logically lowest priority in the
-    system and will thus be used by the IDLE task.
-    Priority zero is reserved for internal use by RTEMS and is not available to
-    applications.
-    Reducing the number of priorities through this configuration option reduces
-    the amount of memory allocated by the schedulers listed above.  These
-    schedulers use a chain control structure per priority and this structure
-    consists of three pointers.  On a 32-bit architecture, the allocated memory
-    is 12 bytes * (``CONFIGURE_MAXIMUM_PRIORITY`` + 1), e.g. 3072 bytes for 256
-    priority levels (default), 48 bytes for 4 priority levels
-    (``CONFIGURE_MAXIMUM_PRIORITY == 3``).
-    The default value is 255, because RTEMS shall support 256 priority levels to
-    be compliant with various standards.  These priorities range from 0 to 255.
 .. index:: CONFIGURE_MAXIMUM_PROCESSORS
 .. _CONFIGURE_MAXIMUM_PROCESSORS:
diff --git a/c-user/config/scheduler-general.rst b/c-user/config/scheduler-general.rst
index 0436100..438e9a3 100644
--- a/c-user/config/scheduler-general.rst
+++ b/c-user/config/scheduler-general.rst
@@ -65,6 +65,64 @@ NOTES:
     This configuration option is only evaluated if the configuration option
     :ref:`CONFIGURE_SCHEDULER_CBS` is defined.
+.. index:: CONFIGURE_MAXIMUM_PRIORITY
+.. index:: maximum priority
+.. index:: number of priority levels
+.. _CONFIGURE_MAXIMUM_PRIORITY:
+CONFIGURE_MAXIMUM_PRIORITY
+CONSTANT:
+    ``CONFIGURE_MAXIMUM_PRIORITY``
+OPTION TYPE:
+    This configuration option is an integer define.
+DEFAULT VALUE:
+    The default value is 255.
+VALUE CONSTRAINTS:
+    The value of this configuration option shall be
+    an element of {3, 7, 31, 63, 127, 255}.
+DESCRIPTION:
+    For the following schedulers
+    * :ref:`SchedulerPriority`, which is the default in uniprocessor
+      configurations and can be configured through the
+      :ref:`CONFIGURE_SCHEDULER_PRIORITY` configuration option,
+    * :ref:`SchedulerSMPPriority` which can be configured through the
+      :ref:`CONFIGURE_SCHEDULER_PRIORITY_SMP` configuration option, and
+    * :ref:`SchedulerSMPPriorityAffinity` which can be configured through the
+      :ref:`CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP` configuration option
+    this configuration option specifies the maximum numeric priority of any task
+    for these schedulers and one less that the number of priority levels for
+    these schedulers.  For all other schedulers provided by RTEMS, this
+    configuration option has no effect.
+NOTES:
+    The numerically greatest priority is the logically lowest priority in the
+    system and will thus be used by the IDLE task.
+    Priority zero is reserved for internal use by RTEMS and is not available to
+    applications.
+    Reducing the number of priorities through this configuration option reduces
+    the amount of memory allocated by the schedulers listed above.  These
+    schedulers use a chain control structure per priority and this structure
+    consists of three pointers.  On a 32-bit architecture, the allocated memory
+    is 12 bytes * (``CONFIGURE_MAXIMUM_PRIORITY`` + 1), e.g. 3072 bytes for 256
+    priority levels (default), 48 bytes for 4 priority levels
+    (``CONFIGURE_MAXIMUM_PRIORITY == 3``).
+    The default value is 255, because RTEMS shall support 256 priority levels to
+    be compliant with various standards.  These priorities range from 0 to 255.
 .. index:: CONFIGURE_SCHEDULER_ASSIGNMENTS
 .. _CONFIGURE_SCHEDULER_ASSIGNMENTS:
2.16.4
