[PATCH v2] doc: Moving BSP Content to User Manual (#3905)
Wed Apr 1 22:21:11 UTC 2020
On Wed, Apr 1, 2020 at 4:19 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Apr 1, 2020 at 3:56 PM Mritunjay <mritunjaysharma394 at gmail.com> wrote:
> >  user/bsps/bsps-m68k.rst | 196 +++++++++++++++++++++++++++++++++++++++-
> >  1 file changed, 194 insertions(+), 2 deletions(-)
> > diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> > index 60882fb..84f5f9d 100644
> > --- a/user/bsps/bsps-m68k.rst
> > +++ b/user/bsps/bsps-m68k.rst
> > @@ -1,6 +1,13 @@
> >  .. SPDX-License-Identifier: CC-BY-SA-4.0
> >  .. Copyright (C) 2018 embedded brains GmbH
> > +.. Copyright (C) 2008 Mriek
> > +.. Copyright (C) 2011 Richard Campbell
> > +.. Copyright (C) 2010 Daniel Code
> > +.. Copyright (C) 2010 Mattrajca
> > +.. Copyright (C) 2009,2010 Joel Sherill
> > +.. Copyright (C) 2020 Mritunjay Sharma
> I'll have to look back, but most of these are going to be GCI students
> and the wiki names are not real names so the copyrights are not valid.
> Since they all pre-date the circa 2016 handoff from OAR to individual
> copyrights, I think we can just drop these copyright statements from
> the wiki contributions.
> Mritunjay, you should add your copyright only if you have made some
> actual contribution here to the writing, otherwise there should be no
> additional copyrights here (except maybe OAR one for circa 2008-2011
> modifications)
I take the last statement back. Anything contributed to the wiki has
no clear copyright or license terms. However, GCI students'
contributions can be integrated more-or-less as we see fit. I think
someone dug up a few GCI student names before for the user manual
changes to provide the attribution list. It may be challenging.
Either way, copyright statements won't be needed here, I think.
> >  m68k (Motorola 68000 / ColdFire)
> > @@ -53,7 +60,19 @@ TODO.
> >  mcf5329
> > -TODO.
> > +Overview
> > +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a Motorola
> > +evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
> > +development kit features the MCF5329 based Fire Engine, as well as a plug-in
> > +system-on-module containing 32 MB of DDR-SDRAM. The board also includes 2 MB of
> > +boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard 800x600
> > +LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100 Ethernet.
> > +You can find the link to MCF5329 Reference Manual below:
> > +* `MCF5329 Reference Manual <https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
> >  mrm332
> > @@ -73,7 +92,180 @@ TODO.
> >  mvme162
> > -TODO.
> > +Overview
> > +The MVME162 family provides OEMs and solution developers an ideal platform for
> > +embedded monitoring and control apllications it allows an OEM to minimize
> > +engineering expenses while integrating value-added hardware and software
> > +applications onto an off-the-shelf product. In order to provide the wide range
> > +of solutions, the MVME162 allows a variety of MPU, memory, and interface
> > +options such as floating-point, Ethernet, SCSI, and VME. The result is a
> > +variation of the MVME162 which most closely fits the application requirement.
> > +There are a large number of model variations on this board. This was the first
> > +user submitted BSP and continues to be a fairly popular simply because at one
> > +point it was the highest selling VMEBus board of all time.
> > +Board Setup
> > +We will setup the RTEMS Lab Board initally to proceed further for the setup
> > +of TFTP transfer.
> > +The env settings are:
> > +.. code-block:: none
> > +    MPU Clock Speed =25Mhz
> > +    162-Bug>env
> > +    Bug or System environment [B/S] = B?
> > +    Field Service Menu Enable [Y/N] = N?
> > +       Remote Start Method Switch [G/M/B/N] = B?
> > +       Probe System for Supported I/O Controllers [Y/N] = Y?
> > +       Negate VMEbus SYSFAIL* Always [Y/N] = N?
> > +       Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> > +       Local SCSI Bus Negotiations Type [A/S/N]       = A?
> > +       Industry Pack Reset on Debugger Startup [Y/N]  = Y?
> > +       Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
> > +       Auto Boot Enable [Y/N]   = N?
> > +       Auto Boot at power-up only [Y/N] = Y?
> > +       Auto Boot Controller LUN = 00?
> > +       Auto Boot Device LUN     = 00?
> > +       Auto Boot Abort Delay    = 15?
> > +       Auto Boot Default String [NULL for a empty string] = ?
> > +       ROM Boot Enable [Y/N]            = N?
> > +       ROM Boot at power-up only [Y/N]  = Y?
> > +       ROM Boot Enable search of VMEbus [Y/N] = N?
> > +       ROM Boot Abort Delay             = 0?
> > +       ROM Boot Direct Starting Address = FF800000?
> > +       ROM Boot Direct Ending Address   = FFDFFFFC?
> > +       Network Auto Boot Enable [Y/N]   = N?
> > +       Network Auto Boot at power-up only [Y/N] = Y?
> > +       Network Auto Boot Controller LUN = 00?
> > +       Network Auto Boot Device LUN     = 00?
> > +       Network Auto Boot Abort Delay    = 5?
> > +       Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
> > +       Memory Search Starting Address   = 00000000?
> > +       Memory Search Ending Address     = 01000000?
> > +       Memory Search Increment Size     = 00010000?
> > +       Memory Search Delay Enable [Y/N] = N?
> > +       Memory Search Delay Address      = FFFFD20F?
> > +       Memory Size Enable [Y/N]         = Y?
> > +       Memory Size Starting Address     = 00000000?
> > +       Memory Size Ending Address       = 01000000?
> > +       Base Address of Dynamic Memory   = 00000000?
> > +       Size of Parity Memory            = 00000000?
> > +       Size of ECC Memory Board #0      = 01000000?
> > +       Size of ECC Memory Board #1      = 00000000?
> > +       Base Address of Static Memory    = FFE00000?
> > +       Size of Static Memory            = 00020000?
> > +       Slave Enable #1 [Y/N] = Y?
> > +       Slave Starting Address #1 = 00000000?
> > +       Slave Ending Address #1   = 00FFFFFF?
> > +       Slave Address Translation Address #1 = 00000000?
> > +       Slave Address Translation Select #1  = 00000000?
> > +       Slave Control #1 = 03FF?
> > +       Slave Enable #2 [Y/N] = N?
> > +       Slave Starting Address #2 = 00000000?
> > +       Slave Ending Address #2   = 00000000?
> > +       Slave Address Translation Address #2 = 00000000?
> > +       Slave Address Translation Select #2  = 00000000?
> > +       Slave Control #2 = 0000?
> > +       Master Enable #1 [Y/N] = Y?
> > +       Master Starting Address #1 = 01000000?
> > +       Master Ending Address #1   = EFFFFFFF?
> > +       Master Control #1 = 0D?
> > +       Master Enable #2 [Y/N] = N?
> > +       Master Starting Address #2 = 00000000?
> > +       Master Ending Address #2   = 00000000?
> > +       Master Control #2 = 00?
> > +       Master Enable #3 [Y/N] = N?
> > +       Master Starting Address #3 = 00000000?
> > +       Master Ending Address #3   = 00000000?
> > +       Master Control #3 = 00?
> > +       Master Enable #4 [Y/N] = N?
> > +       Master Starting Address #4 = 00000000?
> > +       Master Ending Address #4   = 00000000?
> > +       Master Address Translation Address #4 = 00000000?
> > +       Master Address Translation Select #4  = 00000000?
> > +       Master Control #4 = 00?
> > +       Short I/O (VMEbus A16) Enable [Y/N] = Y?
> > +       Short I/O (VMEbus A16) Control      = 01?
> > +       F-Page (VMEbus A24) Enable [Y/N]    = Y?
> > +       F-Page (VMEbus A24) Control         = 02?
> > +       ROM Access Time Code          = 03?
> > +       FLASH Access Time Code        = 02?
> > +       MCC Vector Base               = 05?
> > +       VMEC2 Vector Base #1          = 06?
> > +       VMEC2 Vector Base #2          = 07?
> > +       VMEC2 GCSR Group Base Address = D2?
> > +       VMEC2 GCSR Board Base Address = 00?
> > +       VMEbus Global Time Out Code   = 01?
> > +       Local Bus Time Out Code       = 02?
> > +       VMEbus Access Time Out Code   = 02?
> > +       IP A Base Address              = 00000000?
> > +       IP B Base Address              = 00000000?
> > +       IP C Base Address              = 00000000?
> > +       IP D Base Address              = 00000000?
> > +       IP D/C/B/A Memory Size         = 00000000?
> > +       IP D/C/B/A General Control     = 00000000?
> > +       IP D/C/B/A Interrupt 0 Control = 00000000?
> > +       IP D/C/B/A Interrupt 1 Control = 00000000?
> > +To setup the Server/Client IP Addresses for the TFTP Transfer, we will use the
> > +NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command commonly
> > +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> > +The NIOT command goes something like this:
> > +    162-Bug>niot
> > +       Controller LUN =00?
> > +       Device LUN     =00?
> > +       Node Control Memory Address =FFE10000?
> > +       Client IP Address      =192.168.1.245?
> > +       Server IP Address      =192.168.1.92?
> > +       Subnet IP Address Mask =255.255.255.0?
> > +       Broadcast IP Address   =192.168.1.255?
> > +       Gateway IP Address     =0.0.0.0?
> > +       Boot File Name ("NULL" for None)     =/mvme162.img?
> > +       Argument File Name ("NULL" for None) =?
> > +       Boot File Load Address         =00020000?
> > +       Boot File Execution Address    =00020000?
> > +       Boot File Execution Delay      =00000000?
> > +       Boot File Length               =00000000?
> > +       Boot File Byte Offset          =00000000?
> > +       BOOTP/RARP Request Retry       =00?
> > +       TFTP/ARP Request Retry         =00?
> > +       Trace Character Buffer Address =00000000?
> > +       BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> > +       BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
> > +Downloading and Executing
> > +Download from the TFTP server using the 162-Bug's "NBO" (Network Boot Operating System) command:
> > +    162-Bug>nbo
> > +    Network Booting from: VME162, Controller 0, Device 0
> > +       Loading: /mvme162.img
> > +       Client IP Address      = 192.168.1.245
> > +       Server IP Address      = 192.168.1.92
> > +       Gateway IP Address     = 0.0.0.0
> > +       Subnet IP Address Mask = 255.255.255.0
> > +       Boot File Name         = /mvme162.img
> > +       Argument File Name     =
> > +       Network Boot File load in progress... To abort hit <BREAK>
> > +       Bytes Received =&356528, Bytes Loaded =&356528
> > +       Bytes/Second   =&89132, Elapsed Time =4 Second(s)
> > +The program will automatically run when download is complete.
> >  mvme167
> > 2.17.1
> > devel mailing list
> > devel at rtems.org
