[PATCH v2] doc: Moving BSP Content to User Manual (#3905)
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Wed Apr 1 22:31:45 UTC 2020
Sent from my iPhone
> On 02-Apr-2020, at 3:51 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Apr 1, 2020 at 4:19 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Apr 1, 2020 at 3:56 PM Mritunjay <mritunjaysharma394 at gmail.com> wrote:
>>> user/bsps/bsps-m68k.rst | 196 +++++++++++++++++++++++++++++++++++++++-
>>> 1 file changed, 194 insertions(+), 2 deletions(-)
>>> diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
>>> index 60882fb..84f5f9d 100644
>>> --- a/user/bsps/bsps-m68k.rst
>>> +++ b/user/bsps/bsps-m68k.rst
>>> @@ -1,6 +1,13 @@
>>> .. SPDX-License-Identifier: CC-BY-SA-4.0
>>> .. Copyright (C) 2018 embedded brains GmbH
>>> +.. Copyright (C) 2008 Mriek
>>> +.. Copyright (C) 2011 Richard Campbell
>>> +.. Copyright (C) 2010 Daniel Code
>>> +.. Copyright (C) 2010 Mattrajca
>>> +.. Copyright (C) 2009,2010 Joel Sherill
>>> +.. Copyright (C) 2020 Mritunjay Sharma
>> I'll have to look back, but most of these are going to be GCI students
>> and the wiki names are not real names so the copyrights are not valid.
>> Since they all pre-date the circa 2016 handoff from OAR to individual
>> copyrights, I think we can just drop these copyright statements from
>> the wiki contributions.
>> Mritunjay, you should add your copyright only if you have made some
>> actual contribution here to the writing, otherwise there should be no
>> additional copyrights here (except maybe OAR one for circa 2008-2011
>> modifications)
> I take the last statement back. Anything contributed to the wiki has
> no clear copyright or license terms. However, GCI students'
> contributions can be integrated more-or-less as we see fit. I think
> someone dug up a few GCI student names before for the user manual
> changes to provide the attribution list. It may be challenging.
> Either way, copyright statements won't be needed here, I think.
Hi Gedare,
I have added few lines that are written by me
(like in Board Setup while describing about NIOT).
Does that qualify for my name to be added in the
Copyright or Should I simply remove all of them
because all are prior to 2016? I guess Chris advised me to find the names of the authors.
>>> m68k (Motorola 68000 / ColdFire)
>>> @@ -53,7 +60,19 @@ TODO.
>>> mcf5329
>>> -TODO.
>>> +Overview
>>> +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a Motorola
>>> +evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
>>> +development kit features the MCF5329 based Fire Engine, as well as a plug-in
>>> +system-on-module containing 32 MB of DDR-SDRAM. The board also includes 2 MB of
>>> +boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard 800x600
>>> +LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100 Ethernet.
>>> +You can find the link to MCF5329 Reference Manual below:
>>> +* `MCF5329 Reference Manual <https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
>>> mrm332
>>> @@ -73,7 +92,180 @@ TODO.
>>> mvme162
>>> -TODO.
>>> +Overview
>>> +The MVME162 family provides OEMs and solution developers an ideal platform for
>>> +embedded monitoring and control apllications it allows an OEM to minimize
>>> +engineering expenses while integrating value-added hardware and software
>>> +applications onto an off-the-shelf product. In order to provide the wide range
>>> +of solutions, the MVME162 allows a variety of MPU, memory, and interface
>>> +options such as floating-point, Ethernet, SCSI, and VME. The result is a
>>> +variation of the MVME162 which most closely fits the application requirement.
>>> +There are a large number of model variations on this board. This was the first
>>> +user submitted BSP and continues to be a fairly popular simply because at one
>>> +point it was the highest selling VMEBus board of all time.
>>> +Board Setup
>>> +We will setup the RTEMS Lab Board initally to proceed further for the setup
>>> +of TFTP transfer.
>>> +The env settings are:
>>> +.. code-block:: none
>>> + MPU Clock Speed =25Mhz
>>> + 162-Bug>env
>>> + Bug or System environment [B/S] = B?
>>> + Field Service Menu Enable [Y/N] = N?
>>> + Remote Start Method Switch [G/M/B/N] = B?
>>> + Probe System for Supported I/O Controllers [Y/N] = Y?
>>> + Negate VMEbus SYSFAIL* Always [Y/N] = N?
>>> + Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
>>> + Local SCSI Bus Negotiations Type [A/S/N] = A?
>>> + Industry Pack Reset on Debugger Startup [Y/N] = Y?
>>> + Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y?
>>> + Auto Boot Enable [Y/N] = N?
>>> + Auto Boot at power-up only [Y/N] = Y?
>>> + Auto Boot Controller LUN = 00?
>>> + Auto Boot Device LUN = 00?
>>> + Auto Boot Abort Delay = 15?
>>> + Auto Boot Default String [NULL for a empty string] = ?
>>> + ROM Boot Enable [Y/N] = N?
>>> + ROM Boot at power-up only [Y/N] = Y?
>>> + ROM Boot Enable search of VMEbus [Y/N] = N?
>>> + ROM Boot Abort Delay = 0?
>>> + ROM Boot Direct Starting Address = FF800000?
>>> + ROM Boot Direct Ending Address = FFDFFFFC?
>>> + Network Auto Boot Enable [Y/N] = N?
>>> + Network Auto Boot at power-up only [Y/N] = Y?
>>> + Network Auto Boot Controller LUN = 00?
>>> + Network Auto Boot Device LUN = 00?
>>> + Network Auto Boot Abort Delay = 5?
>>> + Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
>>> + Memory Search Starting Address = 00000000?
>>> + Memory Search Ending Address = 01000000?
>>> + Memory Search Increment Size = 00010000?
>>> + Memory Search Delay Enable [Y/N] = N?
>>> + Memory Search Delay Address = FFFFD20F?
>>> + Memory Size Enable [Y/N] = Y?
>>> + Memory Size Starting Address = 00000000?
>>> + Memory Size Ending Address = 01000000?
>>> + Base Address of Dynamic Memory = 00000000?
>>> + Size of Parity Memory = 00000000?
>>> + Size of ECC Memory Board #0 = 01000000?
>>> + Size of ECC Memory Board #1 = 00000000?
>>> + Base Address of Static Memory = FFE00000?
>>> + Size of Static Memory = 00020000?
>>> + Slave Enable #1 [Y/N] = Y?
>>> + Slave Starting Address #1 = 00000000?
>>> + Slave Ending Address #1 = 00FFFFFF?
>>> + Slave Address Translation Address #1 = 00000000?
>>> + Slave Address Translation Select #1 = 00000000?
>>> + Slave Control #1 = 03FF?
>>> + Slave Enable #2 [Y/N] = N?
>>> + Slave Starting Address #2 = 00000000?
>>> + Slave Ending Address #2 = 00000000?
>>> + Slave Address Translation Address #2 = 00000000?
>>> + Slave Address Translation Select #2 = 00000000?
>>> + Slave Control #2 = 0000?
>>> + Master Enable #1 [Y/N] = Y?
>>> + Master Starting Address #1 = 01000000?
>>> + Master Ending Address #1 = EFFFFFFF?
>>> + Master Control #1 = 0D?
>>> + Master Enable #2 [Y/N] = N?
>>> + Master Starting Address #2 = 00000000?
>>> + Master Ending Address #2 = 00000000?
>>> + Master Control #2 = 00?
>>> + Master Enable #3 [Y/N] = N?
>>> + Master Starting Address #3 = 00000000?
>>> + Master Ending Address #3 = 00000000?
>>> + Master Control #3 = 00?
>>> + Master Enable #4 [Y/N] = N?
>>> + Master Starting Address #4 = 00000000?
>>> + Master Ending Address #4 = 00000000?
>>> + Master Address Translation Address #4 = 00000000?
>>> + Master Address Translation Select #4 = 00000000?
>>> + Master Control #4 = 00?
>>> + Short I/O (VMEbus A16) Enable [Y/N] = Y?
>>> + Short I/O (VMEbus A16) Control = 01?
>>> + F-Page (VMEbus A24) Enable [Y/N] = Y?
>>> + F-Page (VMEbus A24) Control = 02?
>>> + ROM Access Time Code = 03?
>>> + FLASH Access Time Code = 02?
>>> + MCC Vector Base = 05?
>>> + VMEC2 Vector Base #1 = 06?
>>> + VMEC2 Vector Base #2 = 07?
>>> + VMEC2 GCSR Group Base Address = D2?
>>> + VMEC2 GCSR Board Base Address = 00?
>>> + VMEbus Global Time Out Code = 01?
>>> + Local Bus Time Out Code = 02?
>>> + VMEbus Access Time Out Code = 02?
>>> + IP A Base Address = 00000000?
>>> + IP B Base Address = 00000000?
>>> + IP C Base Address = 00000000?
>>> + IP D Base Address = 00000000?
>>> + IP D/C/B/A Memory Size = 00000000?
>>> + IP D/C/B/A General Control = 00000000?
>>> + IP D/C/B/A Interrupt 0 Control = 00000000?
>>> + IP D/C/B/A Interrupt 1 Control = 00000000?
>>> +To setup the Server/Client IP Addresses for the TFTP Transfer, we will use the
>>> +NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command commonly
>>> +used to setup the Server/Client IP Addresses for the TFTP Transfer.
>>> +The NIOT command goes something like this:
>>> + 162-Bug>niot
>>> + Controller LUN =00?
>>> + Device LUN =00?
>>> + Node Control Memory Address =FFE10000?
>>> + Client IP Address =192.168.1.245?
>>> + Server IP Address =192.168.1.92?
>>> + Subnet IP Address Mask =255.255.255.0?
>>> + Broadcast IP Address =192.168.1.255?
>>> + Gateway IP Address =0.0.0.0?
>>> + Boot File Name ("NULL" for None) =/mvme162.img?
>>> + Argument File Name ("NULL" for None) =?
>>> + Boot File Load Address =00020000?
>>> + Boot File Execution Address =00020000?
>>> + Boot File Execution Delay =00000000?
>>> + Boot File Length =00000000?
>>> + Boot File Byte Offset =00000000?
>>> + BOOTP/RARP Request Retry =00?
>>> + TFTP/ARP Request Retry =00?
>>> + Trace Character Buffer Address =00000000?
>>> + BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
>>> + BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
>>> +Downloading and Executing
>>> +Download from the TFTP server using the 162-Bug's "NBO" (Network Boot Operating System) command:
>>> + 162-Bug>nbo
>>> + Network Booting from: VME162, Controller 0, Device 0
>>> + Loading: /mvme162.img
>>> + Client IP Address = 192.168.1.245
>>> + Server IP Address = 192.168.1.92
>>> + Gateway IP Address = 0.0.0.0
>>> + Subnet IP Address Mask = 255.255.255.0
>>> + Boot File Name = /mvme162.img
>>> + Argument File Name =
>>> + Network Boot File load in progress... To abort hit <BREAK>
>>> + Bytes Received =&356528, Bytes Loaded =&356528
>>> + Bytes/Second =&89132, Elapsed Time =4 Second(s)
>>> +The program will automatically run when download is complete.
>>> mvme167
>>> 2.17.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
