[PATCH] arm: ARMv7-M statically initialized vector table
Sebastian Huber
Thu Apr 2 06:13:53 UTC 2020
Statically initialize the ARMv7-M vector table to allow a placement in
ROM with read-only MPU settings.
Change licence to BSD-2-Clause in some files.
bsps/arm/shared/clock/clock-armv7m.c | 39 ++++++++++++------
bsps/arm/shared/irq/irq-armv7m.c | 50 +++++++++++++++--------
bsps/arm/shared/start/start.S | 10 ++---
cpukit/score/cpu/arm/armv7m-initialize.c | 44 ++++++++++++--------
cpukit/score/cpu/arm/include/rtems/score/armv7m.h | 2 +
5 files changed, 93 insertions(+), 52 deletions(-)
diff --git a/bsps/arm/shared/clock/clock-armv7m.c b/bsps/arm/shared/clock/clock-armv7m.c
index 7a51690562..255de1ca42 100644
--- a/bsps/arm/shared/clock/clock-armv7m.c
+++ b/bsps/arm/shared/clock/clock-armv7m.c
@@ -1,15 +1,29 @@
- * Copyright (c) 2011, 2018 Sebastian Huber. All rights reserved.
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2011, 2018 Sebastian Huber
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
#include <bsp/clock-armv7m.h>
@@ -29,7 +43,7 @@ static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *base)
return _ARMV7M_Clock_counter((ARMV7M_Timecounter *) base);
-static void _ARMV7M_Clock_handler(void)
+void _ARMV7M_Clock_handler(void)
_ARMV7M_Interrupt_service_enter();
Clock_isr(NULL);
@@ -38,10 +52,9 @@ static void _ARMV7M_Clock_handler(void)
static void _ARMV7M_Clock_handler_install(void)
- _ARMV7M_Set_exception_priority_and_handler(
+ _ARMV7M_Set_exception_priority(
ARMV7M_VECTOR_SYSTICK,
- BSP_ARMV7M_SYSTICK_PRIORITY,
- _ARMV7M_Clock_handler
+ BSP_ARMV7M_SYSTICK_PRIORITY
diff --git a/bsps/arm/shared/irq/irq-armv7m.c b/bsps/arm/shared/irq/irq-armv7m.c
index 99c0e373bf..84ebeeb159 100644
--- a/bsps/arm/shared/irq/irq-armv7m.c
+++ b/bsps/arm/shared/irq/irq-armv7m.c
@@ -1,27 +1,41 @@
- * Copyright (c) 2011-2012 Sebastian Huber. All rights reserved.
+ * Copyright (C) 2011, 2012 Sebastian Huber
- * Obere Lagerstr. 30
- * 82178 Puchheim
- * Germany
+ * are met:
-#include <string.h>
-#include <rtems/score/armv7m.h>
+#include <bsp/irq-generic.h>
#include <bsp.h>
#include <bsp/irq.h>
-#include <bsp/irq-generic.h>
#include <bsp/linker-symbols.h>
#include <bsp/armv7m-irq.h>
+#include <rtems/score/armv7m.h>
+#include <string.h>
#ifdef ARM_MULTILIB_ARCH_V7M
void bsp_interrupt_vector_enable(rtems_vector_number vector)
@@ -38,9 +52,10 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
rtems_status_code bsp_interrupt_facility_initialize(void)
- int i;
- ARMV7M_Exception_handler *vector_table =
- (ARMV7M_Exception_handler *) bsp_vector_table_begin;
+ ARMV7M_Exception_handler *vector_table;
+ int i;
+ vector_table = (ARMV7M_Exception_handler *) bsp_vector_table_begin;
if (bsp_vector_table_begin != bsp_start_vector_table_begin) {
memcpy(
@@ -53,7 +68,6 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
_ARMV7M_SCB->icsr = ARMV7M_SCB_ICSR_PENDSVCLR | ARMV7M_SCB_ICSR_PENDSTCLR;
for (i = BSP_INTERRUPT_VECTOR_MIN; i <= BSP_INTERRUPT_VECTOR_MAX; ++i) {
- vector_table [ARMV7M_VECTOR_IRQ(i)] = _ARMV7M_NVIC_Interrupt_dispatch;
_ARMV7M_NVIC_Clear_enable(i);
_ARMV7M_NVIC_Clear_pending(i);
_ARMV7M_NVIC_Set_priority(i, BSP_ARMV7M_IRQ_PRIORITY_DEFAULT);
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index e56b07fefe..93590c1c36 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -5,7 +5,7 @@
- * Copyright (c) 2008, 2019 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2008, 2020 embedded brains GmbH. All rights reserved.
* Dornierstr. 4
@@ -456,13 +456,13 @@ bsp_start_vector_table_begin:
.word _ARMV7M_Exception_default /* Reserved */
- .word _ARMV7M_Exception_default /* SVC */
+ .word _ARMV7M_Supervisor_call /* SVC */
.word _ARMV7M_Exception_default /* Debug Monitor */
- .word _ARMV7M_Exception_default /* PendSV */
- .word _ARMV7M_Exception_default /* SysTick */
+ .word _ARMV7M_Pendable_service_call /* PendSV */
+ .word _ARMV7M_Clock_handler /* SysTick */
.rept BSP_INTERRUPT_VECTOR_MAX + 1
- .word _ARMV7M_Exception_default /* IRQ */
+ .word _ARMV7M_NVIC_Interrupt_dispatch /* IRQ */
.endr
bsp_start_vector_table_end:
diff --git a/cpukit/score/cpu/arm/armv7m-initialize.c b/cpukit/score/cpu/arm/armv7m-initialize.c
index 4f0e0e4fe6..6ec863fa30 100644
--- a/cpukit/score/cpu/arm/armv7m-initialize.c
+++ b/cpukit/score/cpu/arm/armv7m-initialize.c
@@ -1,3 +1,5 @@
* @file
@@ -5,21 +7,33 @@
- * Copyright (c) 2011 Sebastian Huber. All rights reserved.
+ * Copyright (C) 2011 Sebastian Huber
- * 82178 Puchheim
- * Germany
+ * are met:
#ifdef HAVE_CONFIG_H
- #include "config.h"
+#include "config.h"
#endif
@@ -35,15 +49,13 @@ void _CPU_Initialize( void )
* also "ARMv7-M Architecture Reference Manual, Issue D" section B1.5.4
* "Exception priorities and preemption".
ARMV7M_VECTOR_SVC,
- ARMV7M_EXCEPTION_PRIORITY_LOWEST,
- _ARMV7M_Supervisor_call
+ ARMV7M_EXCEPTION_PRIORITY_LOWEST
ARMV7M_VECTOR_PENDSV,
- _ARMV7M_Pendable_service_call
diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
index a6cc8a34ac..c701e1037c 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
@@ -609,6 +609,8 @@ void _ARMV7M_Pendable_service_call( void );
void _ARMV7M_Supervisor_call( void );
+void _ARMV7M_Clock_handler( void );
#endif /* ASM */
#endif /* ARM_MULTILIB_ARCH_V7M */
2.16.4
