[PATCH] arm: ARMv7-M statically initialized vector table
Thu Apr 2 14:22:47 UTC 2020
Ok
On Thu, Apr 2, 2020 at 12:14 AM Sebastian Huber
> Statically initialize the ARMv7-M vector table to allow a placement in
> ROM with read-only MPU settings.
> Change licence to BSD-2-Clause in some files.
>  bsps/arm/shared/clock/clock-armv7m.c              | 39 ++++++++++++------
>  bsps/arm/shared/irq/irq-armv7m.c                  | 50 +++++++++++++++--------
>  bsps/arm/shared/start/start.S                     | 10 ++---
>  cpukit/score/cpu/arm/armv7m-initialize.c          | 44 ++++++++++++--------
>  cpukit/score/cpu/arm/include/rtems/score/armv7m.h |  2 +
>  5 files changed, 93 insertions(+), 52 deletions(-)
> diff --git a/bsps/arm/shared/clock/clock-armv7m.c b/bsps/arm/shared/clock/clock-armv7m.c
> index 7a51690562..255de1ca42 100644
> --- a/bsps/arm/shared/clock/clock-armv7m.c
> +++ b/bsps/arm/shared/clock/clock-armv7m.c
> @@ -1,15 +1,29 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> - * Copyright (c) 2011, 2018 Sebastian Huber.  All rights reserved.
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> + * Copyright (C) 2011, 2018 Sebastian Huber
> - *  embedded brains GmbH
> - *  Dornierstr. 4
> - *  82178 Puchheim
> - *  Germany
> - *  <rtems at embedded-brains.de>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
>  #include <bsp/clock-armv7m.h>
> @@ -29,7 +43,7 @@ static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *base)
>    return _ARMV7M_Clock_counter((ARMV7M_Timecounter *) base);
> -static void _ARMV7M_Clock_handler(void)
> +void _ARMV7M_Clock_handler(void)
>    _ARMV7M_Interrupt_service_enter();
>    Clock_isr(NULL);
> @@ -38,10 +52,9 @@ static void _ARMV7M_Clock_handler(void)
>  static void _ARMV7M_Clock_handler_install(void)
> -  _ARMV7M_Set_exception_priority_and_handler(
> +  _ARMV7M_Set_exception_priority(
>      ARMV7M_VECTOR_SYSTICK,
> -    BSP_ARMV7M_SYSTICK_PRIORITY,
> -    _ARMV7M_Clock_handler
> +    BSP_ARMV7M_SYSTICK_PRIORITY
> diff --git a/bsps/arm/shared/irq/irq-armv7m.c b/bsps/arm/shared/irq/irq-armv7m.c
> index 99c0e373bf..84ebeeb159 100644
> --- a/bsps/arm/shared/irq/irq-armv7m.c
> +++ b/bsps/arm/shared/irq/irq-armv7m.c
> @@ -1,27 +1,41 @@
> - * Copyright (c) 2011-2012 Sebastian Huber.  All rights reserved.
> + * Copyright (C) 2011, 2012 Sebastian Huber
> - *  Obere Lagerstr. 30
> - *  82178 Puchheim
> - *  Germany
> + * are met:
> -#include <string.h>
> -#include <rtems/score/armv7m.h>
> +#include <bsp/irq-generic.h>
>  #include <bsp.h>
>  #include <bsp/irq.h>
> -#include <bsp/irq-generic.h>
>  #include <bsp/linker-symbols.h>
>  #include <bsp/armv7m-irq.h>
> +#include <rtems/score/armv7m.h>
> +#include <string.h>
>  #ifdef ARM_MULTILIB_ARCH_V7M
>  void bsp_interrupt_vector_enable(rtems_vector_number vector)
> @@ -38,9 +52,10 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
>  rtems_status_code bsp_interrupt_facility_initialize(void)
> -  int i;
> -  ARMV7M_Exception_handler *vector_table =
> -    (ARMV7M_Exception_handler *) bsp_vector_table_begin;
> +  ARMV7M_Exception_handler *vector_table;
> +  int                       i;
> +  vector_table = (ARMV7M_Exception_handler *) bsp_vector_table_begin;
>    if (bsp_vector_table_begin != bsp_start_vector_table_begin) {
>      memcpy(
> @@ -53,7 +68,6 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
>    _ARMV7M_SCB->icsr = ARMV7M_SCB_ICSR_PENDSVCLR | ARMV7M_SCB_ICSR_PENDSTCLR;
>    for (i = BSP_INTERRUPT_VECTOR_MIN; i <= BSP_INTERRUPT_VECTOR_MAX; ++i) {
> -    vector_table [ARMV7M_VECTOR_IRQ(i)] = _ARMV7M_NVIC_Interrupt_dispatch;
>      _ARMV7M_NVIC_Clear_enable(i);
>      _ARMV7M_NVIC_Clear_pending(i);
>      _ARMV7M_NVIC_Set_priority(i, BSP_ARMV7M_IRQ_PRIORITY_DEFAULT);
> diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
> index e56b07fefe..93590c1c36 100644
> --- a/bsps/arm/shared/start/start.S
> +++ b/bsps/arm/shared/start/start.S
> @@ -5,7 +5,7 @@
> - * Copyright (c) 2008, 2019 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2008, 2020 embedded brains GmbH.  All rights reserved.
>   *  Dornierstr. 4
> @@ -456,13 +456,13 @@ bsp_start_vector_table_begin:
>         .word   _ARMV7M_Exception_default /* Reserved */
> -       .word   _ARMV7M_Exception_default /* SVC */
> +       .word   _ARMV7M_Supervisor_call /* SVC */
>         .word   _ARMV7M_Exception_default /* Debug Monitor */
> -       .word   _ARMV7M_Exception_default /* PendSV */
> -       .word   _ARMV7M_Exception_default /* SysTick */
> +       .word   _ARMV7M_Pendable_service_call /* PendSV */
> +       .word   _ARMV7M_Clock_handler /* SysTick */
>         .rept   BSP_INTERRUPT_VECTOR_MAX + 1
> -       .word   _ARMV7M_Exception_default /* IRQ */
> +       .word   _ARMV7M_NVIC_Interrupt_dispatch /* IRQ */
>         .endr
>  bsp_start_vector_table_end:
> diff --git a/cpukit/score/cpu/arm/armv7m-initialize.c b/cpukit/score/cpu/arm/armv7m-initialize.c
> index 4f0e0e4fe6..6ec863fa30 100644
> --- a/cpukit/score/cpu/arm/armv7m-initialize.c
> +++ b/cpukit/score/cpu/arm/armv7m-initialize.c
> @@ -1,3 +1,5 @@
>   * @file
> @@ -5,21 +7,33 @@
> - * Copyright (c) 2011 Sebastian Huber.  All rights reserved.
> + * Copyright (C) 2011 Sebastian Huber
> - *  82178 Puchheim
> - *  Germany
> + * are met:
>  #ifdef HAVE_CONFIG_H
> -  #include "config.h"
> +#include "config.h"
>  #endif
> @@ -35,15 +49,13 @@ void _CPU_Initialize( void )
>     * also "ARMv7-M Architecture Reference Manual, Issue D" section B1.5.4
>     * "Exception priorities and preemption".
>      ARMV7M_VECTOR_SVC,
> -    ARMV7M_EXCEPTION_PRIORITY_LOWEST,
> -    _ARMV7M_Supervisor_call
> +    ARMV7M_EXCEPTION_PRIORITY_LOWEST
>      ARMV7M_VECTOR_PENDSV,
> -    _ARMV7M_Pendable_service_call
> diff --git a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> index a6cc8a34ac..c701e1037c 100644
> --- a/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> +++ b/cpukit/score/cpu/arm/include/rtems/score/armv7m.h
> @@ -609,6 +609,8 @@ void _ARMV7M_Pendable_service_call( void );
>  void _ARMV7M_Supervisor_call( void );
> +void _ARMV7M_Clock_handler( void );
>  #endif /* ASM */
>  #endif /* ARM_MULTILIB_ARCH_V7M */
> 2.16.4
> devel mailing list
> devel at rtems.org
