[PATCH] config: Remove filesystem entry config options
Chris Johns
chrisj at rtems.org
Thu Apr 2 09:11:53 UTC 2020
On 2020-04-02 18:39, Sebastian Huber wrote:
> On 31/03/2020 12:48, Sebastian Huber wrote:
>> Remove the following undocumented configuration options:
>> * CONFIGURE_FILESYSTEM_ENTRY_DEVFS
>> * CONFIGURE_FILESYSTEM_ENTRY_DOSFS
>> * CONFIGURE_FILESYSTEM_ENTRY_FTPFS
>> * CONFIGURE_FILESYSTEM_ENTRY_IMFS
>> * CONFIGURE_FILESYSTEM_ENTRY_JFFS2
>> * CONFIGURE_FILESYSTEM_ENTRY_NFS
>> * CONFIGURE_FILESYSTEM_ENTRY_RFS
>> * CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
> What about this change? I would like to get the configuration cleaned up
> and fully documented before the 5.1 release.
OK and understandable as it is an on going task.
How much more is there for this task?
