[PATCH] config: Remove filesystem entry config options
Sebastian Huber
Thu Apr 2 09:13:46 UTC 2020
On 02/04/2020 11:11, Chris Johns wrote:
> On 2020-04-02 18:39, Sebastian Huber wrote:
>> On 31/03/2020 12:48, Sebastian Huber wrote:
>>> Remove the following undocumented configuration options:
>>> * CONFIGURE_FILESYSTEM_ENTRY_DEVFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_DOSFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_FTPFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_IMFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_JFFS2
>>> * CONFIGURE_FILESYSTEM_ENTRY_NFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_RFS
>>> * CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
>> What about this change? I would like to get the configuration cleaned
>> up and fully documented before the 5.1 release.
> OK and understandable as it is an on going task.
> How much more is there for this task?
This and this:
https://lists.rtems.org/pipermail/devel/2020-April/058842.html
Plus everything a potential review finds.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/f1587635/attachment.html>
