[PATCH] eng: Add documentation guidelines
Chris Johns
chrisj at rtems.org
Thu Apr 2 09:13:15 UTC 2020
On 2020-04-02 19:25, Sebastian Huber wrote:
> Start with templates for the application configuration options.
> Remove "Format to be followed for making changes in this file" from
> c-user.
> Update #3910.
OK.
> c-user/config/intro.rst | 44 ---------------------------
> eng/doc-guide.rst | 79 +++++++++++++++++++++++++++++++++++++++++++++++++
> eng/management.rst | 1 +
> 3 files changed, 80 insertions(+), 44 deletions(-)
> create mode 100644 eng/doc-guide.rst
> diff --git a/c-user/config/intro.rst b/c-user/config/intro.rst
> index 46267d7..4c2f715 100644
> --- a/c-user/config/intro.rst
> +++ b/c-user/config/intro.rst
> @@ -151,50 +151,6 @@ In general, ``<rtems/confdefs.h>`` is very accurate when given enough
> information. However, it is quite easy to use a library and forget to account
> for its resources.
> -Format to be followed for making changes in this file
> -MACRO NAME:
> - Should be alphanumeric. Can have '_' (underscore).
> -DATA TYPE:
> - Please refer to all existing formats.
> -RANGE:
> - The range depends on the Data Type of the macro.
> - - If the data type is of type task priority, then its value should be an
> - integer in the range of 1 to 255.
> - - If the data type is an integer, then it can have numbers, characters (in
> - case the value is defined using another macro) and arithmetic operations
> - - If the data type is a function pointer the first character should be an
> - alphabet or an underscore. The rest of the string can be alphanumeric.
> - - If the data type is RTEMS Attributes or RTEMS Mode then the string should
> - be alphanumeric.
> - - If the data type is RTEMS NAME then the value should be an integer>=0 or
> - ``RTEMS_BUILD_NAME( 'U', 'I', '1', ' ' )``
> -DEFAULT VALUE:
> - The default value should be in the following formats- Please note that the
> - '.' (full stop) is necessary.
> - - In case the value is not defined then: This is not defined by default.
> - - If we know the default value then: The default value is XXX.
> - - If the default value is BSP Specific then: This option is BSP specific.
> -DESCRIPTION:
> - The description of the macro. (No specific format)
> -NOTES:
> - Any further notes. (No specific format)
> Configuration Example
> diff --git a/eng/doc-guide.rst b/eng/doc-guide.rst
> new file mode 100644
> index 0000000..cdcd04f
> --- /dev/null
> +++ b/eng/doc-guide.rst
> @@ -0,0 +1,79 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> +.. _DocGuide:
> +Documentation Guidelines
> +Application Configuration Options
> +Add at least an index entry and a label for the configuration option. Use a
> +pattern of ``CONFIGURE_[A-Z0-9_]+`` for the option name. Use the following
> +template for application configuration feature options:
> +.. code-block:: rst
> + .. index:: CONFIGURE_FEATURE
> + .. _CONFIGURE_FEATURE:
> + CONFIGURE_FEATURE
> + CONSTANT:
> + ``CONFIGURE_FEATURE``
> + OPTION TYPE:
> + This configuration option is a boolean feature define.
> + DEFAULT CONFIGURATION:
> + If this configuration option is undefined, then the described feature is not
> + enabled.
> + DESCRIPTION:
> + In case this configuration option is defined, then feature happens.
> + NOTES:
> + Keep the description short. Add all special cases, usage notes, error
> + conditions, configuration dependencies, references, etc. here to the notes.
> +Use the following template for application configuration integer and
> +initializer options:
> + .. index:: CONFIGURE_VALUE
> + .. _CONFIGURE_VALUE:
> + CONFIGURE_VALUE
> + CONSTANT:
> + ``CONFIGURE_VALUE``
> + OPTION TYPE:
> + This configuration option is an integer (or initializer) define.
> + DEFAULT VALUE:
> + The default value is X.
> + VALUE CONSTRAINTS:
> + The value of this configuration option shall satisfy all of the following
> + constraints:
> + * It shall be greater than or equal to A.
> + * It shall be less than or equal to B.
> + * It shall meet C.
> + DESCRIPTION:
> + The value of this configuration option defines the Y of Z in W.
> + NOTES:
> diff --git a/eng/management.rst b/eng/management.rst
> index 6eb4217..6a8e057 100644
> --- a/eng/management.rst
> +++ b/eng/management.rst
> @@ -16,6 +16,7 @@ Software Development Management
> vc-users
> vc-authors
> coding
> + doc-guide
> python-devel
> change-management
> issue-tracking
