[PATCH] eng: Add documentation guidelines
Sebastian Huber
Thu Apr 2 08:25:34 UTC 2020
Start with templates for the application configuration options.
Remove "Format to be followed for making changes in this file" from
c-user.
Update #3910.
c-user/config/intro.rst | 44 ---------------------------
eng/doc-guide.rst | 79 +++++++++++++++++++++++++++++++++++++++++++++++++
eng/management.rst | 1 +
3 files changed, 80 insertions(+), 44 deletions(-)
create mode 100644 eng/doc-guide.rst
diff --git a/c-user/config/intro.rst b/c-user/config/intro.rst
index 46267d7..4c2f715 100644
--- a/c-user/config/intro.rst
+++ b/c-user/config/intro.rst
@@ -151,50 +151,6 @@ In general, ``<rtems/confdefs.h>`` is very accurate when given enough
information. However, it is quite easy to use a library and forget to account
for its resources.
-Format to be followed for making changes in this file
-MACRO NAME:
- Should be alphanumeric. Can have '_' (underscore).
-DATA TYPE:
- Please refer to all existing formats.
-RANGE:
- The range depends on the Data Type of the macro.
- - If the data type is of type task priority, then its value should be an
- integer in the range of 1 to 255.
- - If the data type is an integer, then it can have numbers, characters (in
- case the value is defined using another macro) and arithmetic operations
- - If the data type is a function pointer the first character should be an
- alphabet or an underscore. The rest of the string can be alphanumeric.
- - If the data type is RTEMS Attributes or RTEMS Mode then the string should
- be alphanumeric.
- - If the data type is RTEMS NAME then the value should be an integer>=0 or
- ``RTEMS_BUILD_NAME( 'U', 'I', '1', ' ' )``
-DEFAULT VALUE:
- The default value should be in the following formats- Please note that the
- '.' (full stop) is necessary.
- - In case the value is not defined then: This is not defined by default.
- - If we know the default value then: The default value is XXX.
- - If the default value is BSP Specific then: This option is BSP specific.
-DESCRIPTION:
- The description of the macro. (No specific format)
-NOTES:
- Any further notes. (No specific format)
Configuration Example
diff --git a/eng/doc-guide.rst b/eng/doc-guide.rst
new file mode 100644
index 0000000..cdcd04f
--- /dev/null
+++ b/eng/doc-guide.rst
@@ -0,0 +1,79 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. _DocGuide:
+Documentation Guidelines
+Application Configuration Options
+Add at least an index entry and a label for the configuration option. Use a
+pattern of ``CONFIGURE_[A-Z0-9_]+`` for the option name. Use the following
+template for application configuration feature options:
+.. code-block:: rst
+ .. index:: CONFIGURE_FEATURE
+ .. _CONFIGURE_FEATURE:
+ CONFIGURE_FEATURE
+ CONSTANT:
+ ``CONFIGURE_FEATURE``
+ OPTION TYPE:
+ This configuration option is a boolean feature define.
+ DEFAULT CONFIGURATION:
+ If this configuration option is undefined, then the described feature is not
+ enabled.
+ DESCRIPTION:
+ In case this configuration option is defined, then feature happens.
+ NOTES:
+ Keep the description short. Add all special cases, usage notes, error
+ conditions, configuration dependencies, references, etc. here to the notes.
+Use the following template for application configuration integer and
+initializer options:
+ .. index:: CONFIGURE_VALUE
+ .. _CONFIGURE_VALUE:
+ CONFIGURE_VALUE
+ CONSTANT:
+ ``CONFIGURE_VALUE``
+ OPTION TYPE:
+ This configuration option is an integer (or initializer) define.
+ DEFAULT VALUE:
+ The default value is X.
+ VALUE CONSTRAINTS:
+ The value of this configuration option shall satisfy all of the following
+ constraints:
+ * It shall be greater than or equal to A.
+ * It shall be less than or equal to B.
+ * It shall meet C.
+ DESCRIPTION:
+ The value of this configuration option defines the Y of Z in W.
+ NOTES:
diff --git a/eng/management.rst b/eng/management.rst
index 6eb4217..6a8e057 100644
--- a/eng/management.rst
+++ b/eng/management.rst
@@ -16,6 +16,7 @@ Software Development Management
vc-users
vc-authors
coding
+ doc-guide
python-devel
change-management
issue-tracking
2.16.4
