Pushed. Thanks.
On 2020-04-02 19:18, Mritunjay wrote:
> Closes #3922
> user/rsb/configuration.rst | 14 +++++++-------
> user/rsb/cross-canadian-cross.rst | 2 +-
> user/rsb/project-sets.rst | 2 +-
> user/rsb/third-party-packages.rst | 2 +-
> 4 files changed, 10 insertions(+), 10 deletions(-)
> diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
> index fc387a1..8c8c87f 100644
> --- a/user/rsb/configuration.rst
> +++ b/user/rsb/configuration.rst
> @@ -181,7 +181,7 @@ errors that can arise.
> The protocol option lets you set a specific protocol. The ``git://`` prefix
> used by the RSB to select a git repository can be removed using *none* or
> -replaced with one of the standard git protcols.
> +replaced with one of the standard git protocols.
> CVS
> @@ -315,7 +315,7 @@ Maps are declared anywhere in the map using the map directive:
> 1. The map is set to ``my-special-map``.
> -Any macro defintions following a map declaration are placed in that map and the
> +Any macro definitions following a map declaration are placed in that map and the
> default map is ``global`` when loading a file. Maps are selected in
> configuration files by using the ``%select`` directive:
> @@ -328,7 +328,7 @@ if present return that value else the ``global`` map is used. Any new macros or
> changes update only the ``global`` map. This may change in future releases so
> please make sure you use the ``override`` attribute.
> -The macro files specificed on the command line are looked for in the
> +The macro files specified on the command line are looked for in the
> ``_configdir`` paths. See <<X1,``_configdir``>> variable for details. Included
> files need to add the ``%{_configdir}`` macro to the start of the file.
> @@ -636,8 +636,8 @@ source packages based on the outer configuration options:
> The remainder of the script is broken in to the various phases of a build. They
> are:
> -. Preperation
> -. Bulding
> +. Preparation
> +. Building
> . Installing, and
> . Cleaning
> @@ -799,8 +799,8 @@ To build this you can use something similar to:
> The build is for a FreeBSD host and the prefix is for user installed
> packages. In this example I cannot let the source builder perform the install
> -because I never run the RSB with root priviledges so a build set or bset tar
> -file is created. This can then be installed using root priviledges.
> +because I never run the RSB with root privileges so a build set or bset tar
> +file is created. This can then be installed using root privileges.
> The command also supplies the ``--trace`` option. The output in the log file
> will contain all the macros.
> diff --git a/user/rsb/cross-canadian-cross.rst b/user/rsb/cross-canadian-cross.rst
> index 8eceed3..7ccd6c3 100644
> --- a/user/rsb/cross-canadian-cross.rst
> +++ b/user/rsb/cross-canadian-cross.rst
> @@ -37,7 +37,7 @@ To build the Curl package for RTEMS you enter the RSB command:
> 2. The ``--host`` command is the RTEMS architecture and version.
> - 3. The BSP is built and installed in the prefix. The arhcitecture must match
> + 3. The BSP is built and installed in the prefix. The architecture must match
> the ``--host`` architecture.
> .. note: Installing Into Different Directories
> diff --git a/user/rsb/project-sets.rst b/user/rsb/project-sets.rst
> index 6eb8729..54a3f8e 100644
> --- a/user/rsb/project-sets.rst
> +++ b/user/rsb/project-sets.rst
> @@ -154,7 +154,7 @@ Patches are added to a component's name and in the ``%prep:`` section the
> patches can be set up, meaning they are applied to source. The patches are
> applied in the order they are added. If there is a dependency make sure you
> order the patches correctly when you add them. You can add any number of
> -patches and the RSB will handle them efficently.
> +patches and the RSB will handle them efficiently.
> Patches can have options. These are added before the patch URL. If no options
> are provided the patch's setup default options are used.
> diff --git a/user/rsb/third-party-packages.rst b/user/rsb/third-party-packages.rst
> index 0d9fa81..8610650 100644
> --- a/user/rsb/third-party-packages.rst
> +++ b/user/rsb/third-party-packages.rst
> @@ -133,7 +133,7 @@ A custom RTEMS patch to an executate's source code can turn it into a function
> that can be called by the RTEMS shell. Users can call the function in their
> executables simulating the running of the package's command. If the package
> does not export the code in a suitable manner please contact the project's
> -commuinity and see if you can work with them to provide a way for the code to
> +community and see if you can work with them to provide a way for the code to
> be exported. This may be difficult because exporting internal headers and
> functions opens the project up to API compatibility issues they did not have
> before. In the simplest case attempting to get the code into a static library
