libbsd failures- atsamv bsp bset
Joel Sherrill
joel at rtems.org
Thu Apr 2 14:03:35 UTC 2020
Hi
The atsamv BSP bset fails with this:
[1846/1914] Linking build/arm-rtems5-atsamv-default/epoch01.exe
/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/tmp/sb-1001-staging/bin/../lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:linkcmds.base:326
cannot move location counter backwards (from 000000002047ab60 to
000000002045f000)
collect2: error: ld returned 1 exit status
cannot move location counter backwards (from 000000002053f960 to
000000002045f000)
000000002045f000)
Waf: Leaving directory
`/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/rtems-libbsd-v236295c67ed0e2ae5d98cf3bbbe253b4a311e8af-x86_64-linux-gnu-1/rtems-libbsd-236295c67ed0e2ae5d98cf3bbbe253b4a311e8af/build/arm-rtems5-atsamv-default'
Build failed
-> task in 'commands01.exe' failed with exit status 1 (run with -v to
display more information)
-> task in 'dhcpcd02.exe' failed with exit status 1 (run with -v to
-> task in 'dhcpcd01.exe' failed with exit status 1 (run with -v to
shell cmd failed: /bin/sh -ex
Is there a mechanism to account for tests that don't fit?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/413b774a/attachment.html>
