[PATCH docs] user/bsp-build: Fix broken cross references.
Thu Apr 2 15:37:42 UTC 2020
pushed
On Thu, Apr 2, 2020 at 5:07 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are
> missing the underscore in front. This breaks any reference to
> them from other sections.
>  user/start/bsp-build.rst | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
> index 33ecb29..59da2fd 100644
> --- a/user/start/bsp-build.rst
> +++ b/user/start/bsp-build.rst
> @@ -29,7 +29,7 @@ use one of the listed methods to build the BSP.
>  In the output in this section the base directory :file:`$HOME/quick-start` was
>  replaced by ``$BASE``.
> -.. QuickStartBSPBuild_RSB:
> +.. _QuickStartBSPBuild_RSB:
>  RSB BSP Build
> @@ -92,7 +92,7 @@ The RSB BSP build can be customised with following RSB command line options:
>  If you have built a BSP with the RSB, you can move on to
>  :ref:`QuickStartBSPTest`.
> -.. QuickStartBSPBuild_Manual:
> +.. _QuickStartBSPBuild_Manual:
>  Manual BSP Build
> 2.17.1
