[PATCH libbsd 02/11] imx6_ccm: Port to RTEMS
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 2 14:42:36 UTC 2020
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Update #3869.
 buildset/default.ini                     |  1 +
 freebsd/sys/arm/freescale/imx/imx6_ccm.c |  7 +++++++
 libbsd.py                                | 21 +++++++++++++++++++++
 rtemsbsd/include/bsp/nexus-devices.h     |  2 ++
 4 files changed, 31 insertions(+)
diff --git a/buildset/default.ini b/buildset/default.ini
index 43ea82a3..ac8c9c48 100644
--- a/buildset/default.ini
+++ b/buildset/default.ini
@@ -40,6 +40,7 @@ dhcpcd = on
 dpaa = on
 evdev = on
 fdt = on
+imx = on
 in_cksum = on
 mdnsresponder = on
 mmc = on
diff --git a/freebsd/sys/arm/freescale/imx/imx6_ccm.c b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
index 2993f1d6..cef79933 100644
--- a/freebsd/sys/arm/freescale/imx/imx6_ccm.c
+++ b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
@@ -92,6 +92,7 @@ WR4(struct ccm_softc *sc, bus_size_t off, uint32_t val)
 static void
 ccm_init_gates(struct ccm_softc *sc)
+#ifndef __rtems__
 	uint32_t reg;
  	/* ahpbdma, aipstz 1 & 2 buses */
@@ -129,6 +130,7 @@ ccm_init_gates(struct ccm_softc *sc)
 	reg = CCGR6_USBOH3 | CCGR6_USDHC1 | CCGR6_USDHC2 |
 	    CCGR6_USDHC3 | CCGR6_USDHC4;
 	WR4(sc, CCM_CCGR6, reg);
+#endif /* __rtems__ */
 static int
@@ -204,7 +206,12 @@ ccm_probe(device_t dev)
 	if (!ofw_bus_status_okay(dev))
 		return (ENXIO);
+#ifndef __rtems__
         if (ofw_bus_is_compatible(dev, "fsl,imx6q-ccm") == 0)
+#else /* __rtems__ */
+        if (ofw_bus_is_compatible(dev, "fsl,imx6q-ccm") == 0 &&
+	    ofw_bus_is_compatible(dev, "fsl,imx6ul-ccm") == 0)
 		return (ENXIO);
 	device_set_desc(dev, "Freescale i.MX6 Clock Control Module");
diff --git a/libbsd.py b/libbsd.py
index d791efe4..eeb1ec4f 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5010,6 +5010,26 @@ class dpaa(builder.Module):
             mm.generator['source']()
+class imx(builder.Module):
+    def __init__(self, manager):
+        super(imx, self).__init__(manager, type(self).__name__)
+    def generate(self):
+        mm = self.manager
+        self.addKernelSpaceHeaderFiles(
+                'sys/arm/freescale/imx/imx6_ccmreg.h',
+                'sys/arm/freescale/imx/imx6_machdep.h',
+                'sys/arm/freescale/imx/imx_machdep.h',
+        self.addKernelSpaceSourceFiles(
+                'sys/arm/freescale/imx/imx6_ccm.c',
+            mm.generator['source']()
 # Tests
@@ -5166,6 +5186,7 @@ def load(mm):
     mm.addModule(dev_nic_broadcomm(mm))
     mm.addModule(nvme(mm))
+    mm.addModule(imx(mm))
     # Add in_chksum
     mm.addModule(in_cksum(mm))
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index a916c664..92665409 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -127,6 +127,8 @@ RTEMS_BSD_DRIVER_MMC;
 RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0, 0, NULL);
 SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
+SYSINIT_DRIVER_REFERENCE(ccm, simplebus);
 SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
 SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
2.16.4
