[PATCH libbsd 11/11] freebsd/imx6_usbphy: Add regulator (vbus-supply).
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Apr 2 14:42:45 UTC 2020
Update #3869.
freebsd/sys/arm/freescale/imx/imx6_usbphy.c | 31 +++++++++++++++++++++++++++++
1 file changed, 31 insertions(+)
diff --git a/freebsd/sys/arm/freescale/imx/imx6_usbphy.c b/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
index ad545601..7df2e124 100644
--- a/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
+++ b/freebsd/sys/arm/freescale/imx/imx6_usbphy.c
@@ -52,6 +52,9 @@ __FBSDID("$FreeBSD$");
#include <arm/freescale/imx/imx_ccmvar.h>
#include <arm/freescale/imx/imx6_anatopreg.h>
#include <arm/freescale/imx/imx6_anatopvar.h>
+#ifdef __rtems__
+#include <dev/extres/regulator/regulator.h>
+#endif /* __rtems__ */
* Hardware register defines.
@@ -70,6 +73,9 @@ struct usbphy_softc {
device_t dev;
struct resource *mem_res;
u_int phy_num;
+#ifdef __rtems__
+ regulator_t supply_vbus;
static struct ofw_compat_data compat_data[] = {
@@ -107,6 +113,10 @@ usbphy_attach(device_t dev)
struct usbphy_softc *sc;
int err, regoff, rid;
+#ifdef __rtems__
+ int rv;
+ phandle_t node;
sc = device_get_softc(dev);
err = 0;
@@ -121,6 +131,27 @@ usbphy_attach(device_t dev)
goto out;
+#ifdef __rtems__
+ node = ofw_bus_get_node(dev);
+ if (OF_hasprop(node, "vbus-supply")) {
+ rv = regulator_get_by_ofw_property(sc->dev, 0, "vbus-supply",
+ &sc->supply_vbus);
+ if (rv != 0) {
+ device_printf(sc->dev,
+ "Cannot get \"vbus\" regulator\n");
+ err = ENXIO;
+ goto out;
+ rv = regulator_enable(sc->supply_vbus);
+ if (rv != 0) {
+ "Cannot enable \"vbus\" regulator\n");
+ err = ENXIO;
+ goto out;
* XXX Totally lame way to get the unit number (but not quite as lame as
* adding an ad-hoc property to the fdt data). This works as long as
2.16.4
