[PATCH rtems-docs] user/imx: Add i.MX6UL/ULL.
Thu Apr 2 14:53:34 UTC 2020
PS: how do you get the repo inlined to the [PATCH xxx] subject line? It's handy.
On Thu, Apr 2, 2020 at 8:51 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Apr 2, 2020 at 8:43 AM Christian Mauderer
> <christian.mauderer at embedded-brains.de> wrote:
> > Update #3869
> >  user/bsps/arm/imx.rst | 49 ++++++++++++++++++++++++++++++++++++++++++++++---
> >  1 file changed, 46 insertions(+), 3 deletions(-)
> > diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
> > index bc93ae3..51c3b7e 100644
> > --- a/user/bsps/arm/imx.rst
> > +++ b/user/bsps/arm/imx.rst
> > @@ -7,9 +7,10 @@ imx (NXP i.MX)
> >  This BSP offers only one variant, the `imx7`.  This variant supports the i.MX
> > -7Dual processor.  The basic hardware initialization is not performed by the
> > -BSP.  A boot loader with device tree support must be used to start the BSP,
> > -e.g. U-Boot.
> > +7Dual processor and the i.MX 6UL/ULL processor family (with slightly different
> > +clock settings).  The basic hardware initialization is not performed by the BSP.
> > +A boot loader with device tree support must be used to start the BSP, e.g.
> > +U-Boot or barebox.
> >  Build Configuration Options
> > @@ -40,9 +41,30 @@ The following options are available at the configure command line.
> >  ``IMX_CCM_UART_HZ``
> >     The UART clock frequency in Hz (default is 24000000).
> > +``IMX_CCM_ECSPI_HZ``
> > +   The ECSPI clock frequency in Hz (default is 67500000).
> >  ``IMX_CCM_AHB_HZ``
> >     The AHB clock frequency in Hz (default is 135000000).
> > +``IMX_CCM_SDHCI_HZ``
> > +   The SDHCI clock frequency in Hz (default is 196363000).
> > +Clock settings for different boards
> > +The default clock settings are targeted for an i.MX 7Dual evaluation board using
> > +U-Boot. Some other boards with different boot loaders need different settings:
> > + * Phytec phyCORE-i.MX 6ULL (system on module) with MCIMX6Y2CVM08AB and a
> > +   barebox bootloader (version ``2019.01.0-bsp-yocto-i.mx6ul-pd19.1.0``):
> > +   * IMX_CCM_IPG_HZ=66000000
> > +   * IMX_CCM_UART_HZ=80000000
> > +   * IMX_CCM_AHB_HZ=66000000
> > +   * IMX_CCM_SDHCI_HZ=198000000
> > +   * IMX_CCM_ECSPI_HZ=60000000
> >  Boot via U-Boot
> > @@ -65,6 +87,14 @@ The ``loadfdt`` command may be not defined in your U-Boot environment.  Just
> >  replace it with the appropriate commands to load the device tree at
> >  ``${fdt_addr}``.
> > +Boot via barebox
> > +The same command like for U-Boot can be used to generate an application image.
> > +In a default configuration barebox expects an fdt image called `oftree` and a
> > +kernel image called `zImage` in the root folder of the bootable medium (e.g. an
> > +SD card).
> >  Clock Driver
> > @@ -133,6 +163,18 @@ system controls:
> >  A value of zero for the time or count disables the interrupt coalescing in the
> >  corresponding direction.
> > +On the Phytec phyCORE-i.MX 6ULL modules the PHY needs an initialization for the
> > +clock. A special PHY driver handles that (``ksz8091rnb``). Add it to your libbsd
> > +config like that:
> > +.. code-block:: c
> > +    #define RTEMS_BSD_CONFIG_BSP_CONFIG
> > +    #define RTEMS_BSD_CONFIG_INIT
> > +    SYSINIT_DRIVER_REFERENCE(ksz8091rnb, miibus);
> > +    #include <machine/rtems-bsd-config.h>
> Is the extra space needed here?
> >  MMC/SDCard Driver
> > @@ -147,3 +189,4 @@ Caveats
> >  The clock and pin configuration support is quite rudimentary and mostly relies
> >  on the boot loader.  For a pin group configuration see
> >  ``imx_iomux_configure_pins()``.  There is no power management support.
> Many docs end without the blank line. It does cause git to complain.
> I'm not sure if we have any rule about it for writing docs.
> > 2.16.4
> > devel mailing list
> > devel at rtems.org
