[PATCH rtems-docs] user/imx: Add i.MX6UL/ULL.
Christian Mauderer
christian.mauderer at embedded-brains.de
Thu Apr 2 14:56:20 UTC 2020
On 02/04/2020 16:53, Gedare Bloom wrote:
> PS: how do you get the repo inlined to the [PATCH xxx] subject line? It's handy.
git format patch supports to set the prefix with:
git format-patch HEAD^ --subject-prefix="PATCH rtems-docs"
I haven't found a good method yet to set it automatically to the repo
name. But With the growing number of repositories in RTEMS I try to add
the prefixes when not comiting to the core.
> On Thu, Apr 2, 2020 at 8:51 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Apr 2, 2020 at 8:43 AM Christian Mauderer
>> <christian.mauderer at embedded-brains.de> wrote:
>>> Update #3869
>>> user/bsps/arm/imx.rst | 49 ++++++++++++++++++++++++++++++++++++++++++++++---
>>> 1 file changed, 46 insertions(+), 3 deletions(-)
>>> diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
>>> index bc93ae3..51c3b7e 100644
>>> --- a/user/bsps/arm/imx.rst
>>> +++ b/user/bsps/arm/imx.rst
>>> @@ -7,9 +7,10 @@ imx (NXP i.MX)
>>> This BSP offers only one variant, the `imx7`. This variant supports the i.MX
>>> -7Dual processor. The basic hardware initialization is not performed by the
>>> -BSP. A boot loader with device tree support must be used to start the BSP,
>>> -e.g. U-Boot.
>>> +7Dual processor and the i.MX 6UL/ULL processor family (with slightly different
>>> +clock settings). The basic hardware initialization is not performed by the BSP.
>>> +A boot loader with device tree support must be used to start the BSP, e.g.
>>> +U-Boot or barebox.
>>> Build Configuration Options
>>> @@ -40,9 +41,30 @@ The following options are available at the configure command line.
>>> ``IMX_CCM_UART_HZ``
>>> The UART clock frequency in Hz (default is 24000000).
>>> +``IMX_CCM_ECSPI_HZ``
>>> + The ECSPI clock frequency in Hz (default is 67500000).
>>> ``IMX_CCM_AHB_HZ``
>>> The AHB clock frequency in Hz (default is 135000000).
>>> +``IMX_CCM_SDHCI_HZ``
>>> + The SDHCI clock frequency in Hz (default is 196363000).
>>> +Clock settings for different boards
>>> +The default clock settings are targeted for an i.MX 7Dual evaluation board using
>>> +U-Boot. Some other boards with different boot loaders need different settings:
>>> + * Phytec phyCORE-i.MX 6ULL (system on module) with MCIMX6Y2CVM08AB and a
>>> + barebox bootloader (version ``2019.01.0-bsp-yocto-i.mx6ul-pd19.1.0``):
>>> + * IMX_CCM_IPG_HZ=66000000
>>> + * IMX_CCM_UART_HZ=80000000
>>> + * IMX_CCM_AHB_HZ=66000000
>>> + * IMX_CCM_SDHCI_HZ=198000000
>>> + * IMX_CCM_ECSPI_HZ=60000000
>>> Boot via U-Boot
>>> @@ -65,6 +87,14 @@ The ``loadfdt`` command may be not defined in your U-Boot environment. Just
>>> replace it with the appropriate commands to load the device tree at
>>> ``${fdt_addr}``.
>>> +Boot via barebox
>>> +The same command like for U-Boot can be used to generate an application image.
>>> +In a default configuration barebox expects an fdt image called `oftree` and a
>>> +kernel image called `zImage` in the root folder of the bootable medium (e.g. an
>>> +SD card).
>>> Clock Driver
>>> @@ -133,6 +163,18 @@ system controls:
>>> A value of zero for the time or count disables the interrupt coalescing in the
>>> corresponding direction.
>>> +On the Phytec phyCORE-i.MX 6ULL modules the PHY needs an initialization for the
>>> +clock. A special PHY driver handles that (``ksz8091rnb``). Add it to your libbsd
>>> +config like that:
>>> +.. code-block:: c
>>> + #define RTEMS_BSD_CONFIG_BSP_CONFIG
>>> + #define RTEMS_BSD_CONFIG_INIT
>>> + SYSINIT_DRIVER_REFERENCE(ksz8091rnb, miibus);
>>> + #include <machine/rtems-bsd-config.h>
>> Is the extra space needed here?
>>> MMC/SDCard Driver
>>> @@ -147,3 +189,4 @@ Caveats
>>> The clock and pin configuration support is quite rudimentary and mostly relies
>>> on the boot loader. For a pin group configuration see
>>> ``imx_iomux_configure_pins()``. There is no power management support.
>> Many docs end without the blank line. It does cause git to complain.
>> I'm not sure if we have any rule about it for writing docs.
>>> 2.16.4
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax: +49-89-18 94 741 - 08
PGP: Public key available on request.
