sqlite build failure on BSP bsets
Thu Apr 2 17:01:15 UTC 2020
Hi
It looks like tclsh is required to build sqlite. I filed this as a ticket
since it is a bit of a broad issue. Added host dependency (docs, sb-check),
no BSP bset builds without it installed, etc.
+ make -j 8 sqlite3.h libsqlite3.la
tclsh
/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mksqlite3h.tcl
>sqlite3.h
gcc  -g -o mkkeywordhash -DSQLITE_OMIT_WAL=1
-DSQLITE_ENABLE_COLUMN_METADATA=1
 /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mkkeywordhash.c
gcc  -g -o lemon
/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/lemon.c
/bin/sh: tclsh: command not found
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/7bf24375/attachment.html>
