sqlite build failure on BSP bsets
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Thu Apr 2 17:08:59 UTC 2020
It depends on how you build it.  If you use the amalgamation, you aren't
running the test suite, and you aren't building any of the other
command-line tools that ship with sqlite, then I don't think you have to
have TCL.
On Thu, Apr 2, 2020 at 11:01 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> It looks like tclsh is required to build sqlite. I filed this as a ticket
> since it is a bit of a broad issue. Added host dependency (docs, sb-check),
> no BSP bset builds without it installed, etc.
> + make -j 8 sqlite3.h libsqlite3.la
> tclsh
> /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mksqlite3h.tcl
> >sqlite3.h
> gcc  -g -o mkkeywordhash -DSQLITE_OMIT_WAL=1
> -DSQLITE_ENABLE_COLUMN_METADATA=1
>  /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mkkeywordhash.c
> gcc  -g -o lemon
> /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/lemon.c
> /bin/sh: tclsh: command not found
> --joel
> devel mailing list
> devel at rtems.org
Jonathan Brandmeyer
Vice President of Software Engineering
PlanetiQ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/a38cb728/attachment.html>
