sqlite build failure on BSP bsets
Joel Sherrill
joel at rtems.org
Thu Apr 2 19:43:12 UTC 2020
Thank you for the detailed feedback.
I am torn between:
+ deleting sqlite from the BSP bset's
+ requiring tclsh to be installed
+ updating the RSB recipe for sqlite.
Given the desire to get a release out the door. I am prone to the first
option with a ticket for 5.2 to update sqlite and re-add it to the BSP
bsets.
Since you obviously use sqlite, if you could tackle updating the RSB
recipe, that would be great and avoid having to do something expedient
to get the release out the door.
Chris will eventually wake up in Sydney and chime in. :)
--joel
On Thu, Apr 2, 2020 at 1:36 PM Jonathan Brandmeyer <jbrandmeyer at planetiq.com>
wrote:
> We just copied the amalgamation's single .c and .h file into our
> repository and built it as a single object into our application. So the
> following recommendations come only from an amateur reading of the sources
> on current rtems-source-builder master.
> 3.8.8 is pretty old. I'd just jump straight to 3.30.1, the current
> release.
> Instead of downloading the sqlite-src zip, download sqlite-amalgamation or
> sqlite-autoconf and use that as a base. I think the bset's configuration
> invocation is OK, except that I would set different CFLAGS as described in
> the next couple of paragraphs. See also
> https://sqlite.org/amalgamation.html
> By default, the SQLite write-ahead-log relies on mmap to share some of its
> index structures between multiple processes. It looks like the current
> RTEMS bset disables the WAL entirely. Using the WAL gives much better
> performance than the rollback journal for write-intensive use cases. We
> used SQLite to reliably buffer up and stitch together segments of our field
> software update process, which fits the WAL very well. We set
> `-DSQLITE_MAX_MMAP_SIZE=0 -DSQLITE_DEFAULT_LOCKING_MODE=1` at compile time
> to avoid mmap's use since RTEMS has neither a VMM nor multiple address
> spaces. It is still up to the application to choose either the WAL or the
> rollback journal. See also https://sqlite.org/wal.html#noshm
> We also added -DSQLITE_ENABLE_MEMSYS5 to our build, and used it to give
> SQLite its own memory spaces to operate on distinct from the rest of our
> application. We explicitly provided it with its own MEMSYS5 heap, page
> cache, and lookaside pools. RTEMS just needs to add the correct
> compile-time option to support this functionality. It is still up to the
> application to configure and monitor those memory pools at runtime. See
> also https://sqlite.org/malloc.html
> HTH,
> On Thu, Apr 2, 2020 at 11:16 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Apr 2, 2020, 12:09 PM Jonathan Brandmeyer <
>> jbrandmeyer at planetiq.com> wrote:
>>> It depends on how you build it. If you use the amalgamation, you aren't
>>> running the test suite, and you aren't building any of the other
>>> command-line tools that ship with sqlite, then I don't think you have to
>>> have TCL.
>> If the configuration command needs to change in the bset, could you
>> suggest the command? It would be appreciated.
>> --joel
>>> On Thu, Apr 2, 2020 at 11:01 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> Hi
>>>> It looks like tclsh is required to build sqlite. I filed this as a
>>>> ticket since it is a bit of a broad issue. Added host dependency (docs,
>>>> sb-check), no BSP bset builds without it installed, etc.
>>>> + make -j 8 sqlite3.h libsqlite3.la
>>>> tclsh
>>>> /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mksqlite3h.tcl
>>>> >sqlite3.h
>>>> gcc -g -o mkkeywordhash -DSQLITE_OMIT_WAL=1
>>>> -DSQLITE_ENABLE_COLUMN_METADATA=1
>>>> /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/mkkeywordhash.c
>>>> gcc -g -o lemon
>>>> /home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sqlite-3.8.8.1-powerpc-rtems5-1/build-xc/../sqlite-src-3080801/tool/lemon.c
>>>> /bin/sh: tclsh: command not found
>>>> --joel
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>> Jonathan Brandmeyer
>>> Vice President of Software Engineering
>>> PlanetiQ
> Jonathan Brandmeyer
> PlanetiQ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/84deb388/attachment-0001.html>
