sqlite build failure on BSP bsets
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Thu Apr 2 19:56:51 UTC 2020
On Thu, Apr 2, 2020 at 1:43 PM Joel Sherrill <joel at rtems.org> wrote:
> Thank you for the detailed feedback.
> I am torn between:
> + deleting sqlite from the BSP bset's
> + requiring tclsh to be installed
> + updating the RSB recipe for sqlite.
> Given the desire to get a release out the door. I am prone to the first
> option with a ticket for 5.2 to update sqlite and re-add it to the BSP
> bsets.
I can see where you're coming from. That said, even having an obsolete
bset in the RSB served as a helpful hint that it worked for someone once
upon a time.
> Since you obviously use sqlite, if you could tackle updating the RSB
> recipe, that would be great and avoid having to do something expedient
> to get the release out the door.
I can make a pass at it. What's the quickest way to iterate on a BSET's
rules? I'd rather not have to wait on GCC and crew to rebuild when I get
it wrong the first time.
> Chris will eventually wake up in Sydney and chime in. :)
Jonathan Brandmeyer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/8c7fc2f4/attachment.html>
