[PATCH v2] Tests for inttype.h methods
Joel Sherrill
joel at rtems.org
Thu Apr 2 22:08:59 UTC 2020
You added a few test cases so they need to be added to the .doc file in the
same directory.
I don't think you changed the test output so the .scn (screen) file should
be OK.
--joel
On Thu, Apr 2, 2020 at 5:30 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
> testsuites/psxtests/psxinttypes01/init.c | 25 +++++++++++++++++++++---
> 1 file changed, 22 insertions(+), 3 deletions(-)
> diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> index 030aa2aa57..d86313b251 100644
> --- a/testsuites/psxtests/psxinttypes01/init.c
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -6,6 +6,7 @@
> * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020, Eshan Dhawan
> * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> * Redistribution and use in source and binary forms, with or without
> @@ -64,11 +65,29 @@ rtems_task Init(rtems_task_argument ignored)
> wchar_t *nptr2_n_errange = L"-9999999999999999999999";
> wchar_t *endptr2 = NULL;
> - intmax_t result_strtoimax;
> + intmax_t result_strtoimax, result_imaxabs, input_1, input_2 ;
> + imaxdiv_t result_exp, result_imaxdiv ;
> uintmax_t result_strtoumax;
> TEST_BEGIN();
> + /* Test for imaxabs */
> + input_1 = -10 ;
> + result_imaxabs = 10 ;
> + rtems_test_assert( imaxabs(input_1) == result_imaxabs );
> + input_1 = 10 ;
> + /* Test for imaxdiv */
> + input_1 = 10 ;
> + input_2 = 3 ;
> + result_exp.quot = input_1 / input_2 ;
> + result_exp.rem = input_1 % input_2 ;
> + result_imaxdiv = imaxdiv(input_1, input_2) ;
> + rtems_test_assert( result_imaxdiv.quot == result_exp.quot &&
> + result_imaxdiv.rem == result_exp.rem );
> /* Test for strtoimax */
> puts( "\nstrtoimax Testcases...." );
> puts( "Valid Inputs - Positive Number" );
> @@ -83,7 +102,7 @@ rtems_task Init(rtems_task_argument ignored)
> rtems_test_assert( result_strtoimax == -123 );
> puts( "Final string pointed by endptr" );
> - rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> + rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> puts( "Valid Input - Positive Number - Number out of Range" );
> result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/8c33f0fe/attachment.html>
