[PATCH docs] user/bsp-build: Fix broken cross references.
G S Niteesh Babu
niteesh.gs at gmail.com
Thu Apr 2 11:06:34 UTC 2020
The QuickStartBSPBuild_Manual and QuickStartBSPBuild_RSB are
missing the underscore in front. This breaks any reference to
them from other sections.
user/start/bsp-build.rst | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index 33ecb29..59da2fd 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -29,7 +29,7 @@ use one of the listed methods to build the BSP.
In the output in this section the base directory :file:`$HOME/quick-start` was
replaced by ``$BASE``.
-.. QuickStartBSPBuild_RSB:
+.. _QuickStartBSPBuild_RSB:
RSB BSP Build
@@ -92,7 +92,7 @@ The RSB BSP build can be customised with following RSB command line options:
If you have built a BSP with the RSB, you can move on to
:ref:`QuickStartBSPTest`.
-.. QuickStartBSPBuild_Manual:
+.. _QuickStartBSPBuild_Manual:
Manual BSP Build
2.17.1
