sqlite build failure on BSP bsets
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Thu Apr 2 22:47:16 UTC 2020
Try this.
I changed the logic which avoids building the sqlite3 shell.  Something
about the way it uses libtool made the old `touch`-based method fail.
There's also a bunch of configuration notes that really ought to be more
visible.
On Thu, Apr 2, 2020 at 2:26 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Apr 2, 2020 at 3:00 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Apr 2, 2020 at 1:57 PM Jonathan Brandmeyer
>> <jbrandmeyer at planetiq.com> wrote:
>> > On Thu, Apr 2, 2020 at 1:43 PM Joel Sherrill <joel at rtems.org> wrote:
>> >> Thank you for the detailed feedback.
>> >> I am torn between:
>> >> + deleting sqlite from the BSP bset's
>> >> + requiring tclsh to be installed
>> >> + updating the RSB recipe for sqlite.
>> >> Given the desire to get a release out the door. I am prone to the first
>> >> option with a ticket for 5.2 to update sqlite and re-add it to the BSP
>> >> bsets.
>> > I can see where you're coming from.  That said, even having an obsolete
>> bset in the RSB served as a helpful hint that it worked for someone once
>> upon a time.
>> >> Since you obviously use sqlite, if you could tackle updating the RSB
>> >> recipe, that would be great and avoid having to do something expedient
>> >> to get the release out the door.
>> >  I can make a pass at it.  What's the quickest way to iterate on a
>> BSET's rules?  I'd rather not have to wait on GCC and crew to rebuild when
>> I get it wrong the first time.
>> Use --dry-run option
> This is good to watch the commands quickly.  But you can just explicitly
> build the one package.
> $ cd rtems
> $ ../source-builder/sb-set-builder \
>      --log=l-sqlite.txt \
>      --prefix=XXXX \
>       databases/sqlite
> Should be very close to working. I hacked my command for dtc so there may
> be a typo.
> This should take seconds.
> It is interesting that you didn't know you can build a single package
> or --dry-run. No foul to you. Just points out that we aren't letting the
> community know the cool things the RSB can do.
> I use the source download only option to get people to download things
> for the tools before they come to the Kick Start class. If they have
> network
> issues, can't fetch git, no admin, etc. then they can deal with those with
> their IT. I can't help with someone's draconian policies. :)
>> >> Chris will eventually wake up in Sydney and chime in. :)
>> > Jonathan Brandmeyer
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
Jonathan Brandmeyer
Vice President of Software Engineering
PlanetiQ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/889b6051/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/889b6051/attachment.bin>
