[PATCH v3] Chapter-on-need-for-RTEMS-specific-cross-compiler
utkarsh.rai60 at gmail.com utkarsh.rai60 at gmail.com
Fri Apr 3 14:54:28 UTC 2020
 user/start/tools.rst | 33 +++++++++++++++++++++++++++++++++
 1 file changed, 33 insertions(+)
diff --git a/user/start/tools.rst b/user/start/tools.rst
index c3f039b..494e95a 100644
--- a/user/start/tools.rst
+++ b/user/start/tools.rst
@@ -76,3 +76,36 @@ source code used.
 Add ``--verbose`` to the GCC command for the the verbose version details.
+Need for RTEMS-Specific Cross-Compiler
+New users are often confused as to why they cannot use their distribution's
+cross-compiler for their target on rtems, e.g., the riscv64-linux-gnu or the
+arm-none-eabi-gcc on RTEMS. Below mentioned are some of the reasons for using
+the RTEMS cross-compiler.
+ ``Correct configuration of Newlib -``
+     Newlib is a C standard library implementation intended for use on embedded
+     systems. Most of the POSIX and libc support for RTEMS is derived from
+     Newlib. The RTEMS cross-compiler configures Newlib correctly for RTEMS.
+ ``Threading in GCC support libraries -``
+     Several threading packages in GCC such as Go threads (libgo), OpenMP
+     (libgomp), and OpenACC need to be customized according to RTEMS. This is
+     done by the RTEMS specific cross-compiler.
+ ``Provide preprocessor define __rtems__ -``
+     The  ``__rtems__``  preprocessor define is used to provide conditional code
+     compilation in source files that are shared with other projects e.g. in
+     Newlib or imported code from FreeBSD.
+ ``Multilib variants to match the BSP -``
+     RTEMS configures GCC to create separate runtime libraries for each
+     supported instruction set, floating point unit, vector unit, word size
+     (e.g. 32-bit and 64-bit), endianness, ABI, processor errata workarounds,
+     and so on in the architecture. These libraries are termed as :ref:`Multilib
+     <TargetArchitectures>` variants. Multilib variants to match the BSP are set
+     by selecting a specific set of machine options using the RTEMS
+     cross-compiler.
2.17.1
