[PATCH] bsp/atsam: Use SDRAM memory map by default
Fri Apr 3 15:09:44 UTC 2020
On Fri, Apr 3, 2020 at 8:56 AM Sebastian Huber
> On 03/04/2020 16:51, Gedare Bloom wrote:
> > Thanks for this, please push it
> Sorry, it was not meant to push. It doesn't fix the problem. The libbsd
> build still fails.
But fewer of the tests?
 I guess if the default configuration is best for applications, then
fine. Maybe this needs to be documented in the relevant BSP docs
section for atsam?
Considering the SDRAM limitations it is not possible to compile libbsd
for this configuration of the board. Can/should we provide a different
linkage for building/testing libbsd or, since there are still
failures, consider it a loss?
I haven't been tracking the libbsd discussion entirely, but do/can we
provide expected-failures for libbsd tests?
Gedare
