[PATCH v5] Tests for inttype.h methods
Eshan dhawan eshandhawan51 at gmail.com
Fri Apr 3 19:15:53 UTC 2020
 testsuites/psxtests/psxinttypes01/init.c      | 28 +++++++++++++++++--
 .../psxtests/psxinttypes01/psxinttypes01.doc  | 10 ++++++-
 2 files changed, 34 insertions(+), 4 deletions(-)
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
index 030aa2aa57..28f7336fb8 100644
--- a/testsuites/psxtests/psxinttypes01/init.c
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -6,6 +6,7 @@
  * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020, Eshan Dhawan
  * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
@@ -64,11 +65,32 @@ rtems_task Init(rtems_task_argument ignored)
   wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
   wchar_t  *endptr2         = NULL;
-  intmax_t  result_strtoimax;
+  intmax_t  result_strtoimax, result_imaxabs, input_1, input_2;
+  imaxdiv_t result_exp, result_imaxdiv;
   uintmax_t result_strtoumax;
   TEST_BEGIN();
+ /* Test for imaxabs */
+  input_1 = -10;
+  result_imaxabs = 10;
+  rtems_test_assert( imaxabs(input_1) == result_imaxabs );
+  input_1 = 10;
+  /* Test for imaxdiv */
+  input_1 = 10;
+  input_2 = 3;
+  result_exp.quot = input_1 / input_2;
+  result_exp.rem =  input_1 % input_2;
+  result_imaxdiv = imaxdiv( input_1, input_2 );
+    result_imaxdiv.quot == result_exp.quot &&
+    result_imaxdiv.rem == result_exp.rem
   /* Test for strtoimax  */
   puts( "\nstrtoimax Testcases...." );
   puts( "Valid Inputs - Positive Number" );
@@ -83,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
   rtems_test_assert( result_strtoimax == -123 );
   puts( "Final string pointed by endptr" );
-  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
+  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
   puts( "Valid Input - Positive Number - Number out of Range" );
   result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
index 19f63af34b..59b76796e2 100644
--- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
@@ -1,4 +1,4 @@
-This File describes the concepts tested by this test suite.
+This File describes the concepts tested by this test suite.
 inttypes.h - fixed size integer types
@@ -37,3 +37,11 @@ test suite name: PSXINTTYPE 01
 	- checks for output for string having a negative number - Number Out of Range
 	- checks for final string pointed by endptr
 	- checks for output for invalid argument - Invalid Base
+- Checks for imaxabs Testcases
+	- checks for output with an input with any negative number
+	- checks for output with an input with any positive number
+- Checks for imaxdiv Testcases
+	- checks for the output quotient and remainder with input with positive numbers
2.17.1
