[PATCH v5] Tests for inttype.h methods
Eshan Dhawan
eshandhawan51 at gmail.com
Tue Apr 7 19:13:23 UTC 2020
I sent this patch a few days ago.
if anyone could look at it.
the code was tested by dr joel.
But had some style issues.
I have covered all the suggestions.
Do any more changes need to be made before it is merged?
Thanks
-Eshan
On Sat, Apr 4, 2020 at 12:46 AM Eshan dhawan <eshandhawan51 at gmail.com>
wrote:
> testsuites/psxtests/psxinttypes01/init.c | 28 +++++++++++++++++--
> .../psxtests/psxinttypes01/psxinttypes01.doc | 10 ++++++-
> 2 files changed, 34 insertions(+), 4 deletions(-)
> diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> index 030aa2aa57..28f7336fb8 100644
> --- a/testsuites/psxtests/psxinttypes01/init.c
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -6,6 +6,7 @@
> * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020, Eshan Dhawan
> * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> * Redistribution and use in source and binary forms, with or without
> @@ -64,11 +65,32 @@ rtems_task Init(rtems_task_argument ignored)
> wchar_t *nptr2_n_errange = L"-9999999999999999999999";
> wchar_t *endptr2 = NULL;
> - intmax_t result_strtoimax;
> + intmax_t result_strtoimax, result_imaxabs, input_1, input_2;
> + imaxdiv_t result_exp, result_imaxdiv;
> uintmax_t result_strtoumax;
> TEST_BEGIN();
> + /* Test for imaxabs */
> + input_1 = -10;
> + result_imaxabs = 10;
> + rtems_test_assert( imaxabs(input_1) == result_imaxabs );
> + input_1 = 10;
> + /* Test for imaxdiv */
> + input_1 = 10;
> + input_2 = 3;
> + result_exp.quot = input_1 / input_2;
> + result_exp.rem = input_1 % input_2;
> + result_imaxdiv = imaxdiv( input_1, input_2 );
> + result_imaxdiv.quot == result_exp.quot &&
> + result_imaxdiv.rem == result_exp.rem
> /* Test for strtoimax */
> puts( "\nstrtoimax Testcases...." );
> puts( "Valid Inputs - Positive Number" );
> @@ -83,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
> rtems_test_assert( result_strtoimax == -123 );
> puts( "Final string pointed by endptr" );
> - rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> + rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> puts( "Valid Input - Positive Number - Number out of Range" );
> result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> index 19f63af34b..59b76796e2 100644
> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> @@ -1,4 +1,4 @@
> -This File describes the concepts tested by this test suite.
> +This File describes the concepts tested by this test suite.
> inttypes.h - fixed size integer types
> @@ -37,3 +37,11 @@ test suite name: PSXINTTYPE 01
> - checks for output for string having a negative number - Number
> Out of Range
> - checks for final string pointed by endptr
> - checks for output for invalid argument - Invalid Base
> +- Checks for imaxabs Testcases
> + - checks for output with an input with any negative number
> + - checks for output with an input with any positive number
> +- Checks for imaxdiv Testcases
> + - checks for the output quotient and remainder with input with
> positive numbers
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/a4e1b321/attachment.html>
