Failures on Overnight build sweep
Joel Sherrill
joel at rtems.org
Sun Apr 5 16:28:45 UTC 2020
Hi
It will take me some time to go through all the failures reported on my
overnight sweep (which isn't finished everywhere) for Centos 7, Ubuntu,
and FreeBSD.
Please try to look at the failure messages at
https://lists.rtems.org/pipermail/build/2020-April/date.html
And see if you can help identify the various root causes and fix them.
It appears that a number of the BSP bsets do not build to completion
on Centos, many things fail on FreeBSD 12, etc. For example, this
for the PC BSP bset on CentOS:
https://lists.rtems.org/pipermail/build/2020-April/012862.html
The rasperrypi2 bset build failure is well-known and has a ticket.
Help is really appreciated triaging and fixing these.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/730961fb/attachment-0001.html>
