Failures on Overnight build sweep
Christian Mauderer
oss at c-mauderer.de
Sun Apr 5 19:04:12 UTC 2020
Hello Joel,
libbsd on raspberry should work again since yesterday (if you refer to
that ticket: https://devel.rtems.org/ticket/3903).
Did your build already include the revert here:
https://git.rtems.org/rtems/commit/?id=d582d0e130a463842e27070a2e85ebc1acc7b71f
Sebastian reverted it after Chris said that it broke some builds:
https://lists.rtems.org/pipermail/devel/2020-April/059014.html
Best regards
Christian
On 05/04/2020 18:28, Joel Sherrill wrote:
> Hi
> It will take me some time to go through all the failures reported on my
> overnight sweep (which isn't finished everywhere) for Centos 7, Ubuntu,
> and FreeBSD.
> Please try to look at the failure messages at
> https://lists.rtems.org/pipermail/build/2020-April/date.html
> And see if you can help identify the various root causes and fix them.
> It appears that a number of the BSP bsets do not build to completion
> on Centos, many things fail on FreeBSD 12, etc. For example, this
> for the PC BSP bset on CentOS:
> https://lists.rtems.org/pipermail/build/2020-April/012862.html
> The rasperrypi2 bset build failure is well-known and has a ticket.
> Help is really appreciated triaging and fixing these.
> --joel
> devel mailing list
> devel at rtems.org
