Failures on Overnight build sweep
Joel Sherrill
joel at rtems.org
Sun Apr 5 20:45:55 UTC 2020
On Sun, Apr 5, 2020, 3:09 PM Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
wrote:
> On Sun, 5 Apr 2020 at 21:00, Joel Sherrill <joel at rtems.org> wrote:
> > On Sun, Apr 5, 2020 at 2:54 PM Hesham Almatary <
> hesham.almatary at cl.cam.ac.uk> wrote:
> >> On Sun, 5 Apr 2020 at 20:31, Joel Sherrill <joel at rtems.org> wrote:
> >> > RTEMS is using this hash: 50782bc5cf00bbaa3ac5200009c6a901f7a52905
> >> > RSB is using this hash: 113c65cb56d04c59a0e145f85864fb431419dfa9
> >> > I can see a couple of fairly obvious odd issues beyond probably
> missing
> >> > the patches you mention:
> >> > + dtc is older as an RSB recipe by itself than when built with Spike
> >> > + spike doesn't build on FreeBSD
> >> We may pull this patch in RSB to build Spike on FreeBSD
> >> https://github.com/CTSRD-CHERI/riscv-isa-sim/pull/7/
> > Hesham, can you update the Spike RSB to do that?
> Unfortunately I don't have a FreeBSD box to test on. I can test it on
> Linux, but I won't build if it works on FreeBDS or not.
You get the patch ready and I will test it for you.
In case you haven't heard me, these test sweeps are running about ~24 hours
on a fast machine (8 core Xeon) and ~33 on an early quad-core.
If people want specific patches tested on FreeBSD between big runs, I can
start doing that.
> > And it shouldn't take much time while you are there to bump the dtc
> > to the same as in the spike recipe.
> > Please and thank you.
> >> > + GDB build issue with iconv on FreeBSD 12.
> >> > + Did the atsamv issue where it couldn't link all rtems-libbsd tests
> get fixed?
> >> > It takes a while to dig through the failures. I trust the failures on
> Centos and
> >> > Ubuntu to be RTEMS related while the FreeBSD ones tend to be in tools.
> >> > And that triggers more not working.
> >> > --joel
> >> > On Sun, Apr 5, 2020 at 2:04 PM Christian Mauderer <oss at c-mauderer.de>
> wrote:
> >> >> Hello Joel,
> >> >> libbsd on raspberry should work again since yesterday (if you refer
> to
> >> >> that ticket: https://devel.rtems.org/ticket/3903).
> >> >> Did your build already include the revert here:
> https://git.rtems.org/rtems/commit/?id=d582d0e130a463842e27070a2e85ebc1acc7b71f
> >> >> Sebastian reverted it after Chris said that it broke some builds:
> >> >> https://lists.rtems.org/pipermail/devel/2020-April/059014.html
> >> >> Best regards
> >> >> Christian
> >> >> On 05/04/2020 18:28, Joel Sherrill wrote:
> >> >> > Hi
> >> >> > It will take me some time to go through all the failures reported
> on my
> >> >> > overnight sweep (which isn't finished everywhere) for Centos 7,
> Ubuntu,
> >> >> > and FreeBSD.
> >> >> > Please try to look at the failure messages at
> >> >> > https://lists.rtems.org/pipermail/build/2020-April/date.html
> >> >> > And see if you can help identify the various root causes and fix
> them.
> >> >> > It appears that a number of the BSP bsets do not build to
> completion
> >> >> > on Centos, many things fail on FreeBSD 12, etc. For example, this
> >> >> > for the PC BSP bset on CentOS:
> >> >> > https://lists.rtems.org/pipermail/build/2020-April/012862.html
> >> >> > The rasperrypi2 bset build failure is well-known and has a ticket.
> >> >> > Help is really appreciated triaging and fixing these.
> >> >> > --joel
> >> >> > _______________________________________________
> >> >> > devel mailing list
> >> >> > devel at rtems.org
> >> >> > http://lists.rtems.org/mailman/listinfo/devel
> >> > devel mailing list
> >> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/dd56af15/attachment-0001.html>
