Failures on Overnight build sweep
Chris Johns
chrisj at rtems.org
Sun Apr 5 23:40:17 UTC 2020
On 2020-04-06 09:11, Joel Sherrill wrote:
> On Sun, Apr 5, 2020, 5:55 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 2020-04-06 05:04, Christian Mauderer wrote:
> > libbsd on raspberry should work again since yesterday (if you
> refer to
> > that ticket: https://devel.rtems.org/ticket/3903).
> Did the libbsd config in the RSB get updated?
> I have no idea. Someone who is fixing issues in libbsd should check that
> and ensure the RSB reflects the best state of the world. Otherwise, my
> testing is a huge HUGE waste of time.
> Ditto for rtems-tools fixes and other repos. If you fix something, bump
> hashes
It might be the rtems-kernel that needs to be update ....
https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-5.cfg
