Failures on Overnight build sweep
Joel Sherrill
joel at rtems.org
Mon Apr 6 00:17:44 UTC 2020
On Sun, Apr 5, 2020 at 6:40 PM Chris Johns <chrisj at rtems.org> wrote:
> On 2020-04-06 09:11, Joel Sherrill wrote:
> > On Sun, Apr 5, 2020, 5:55 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 2020-04-06 05:04, Christian Mauderer wrote:
> > > libbsd on raspberry should work again since yesterday (if you
> > refer to
> > > that ticket: https://devel.rtems.org/ticket/3903).
> > Did the libbsd config in the RSB get updated?
> > I have no idea. Someone who is fixing issues in libbsd should check that
> > and ensure the RSB reflects the best state of the world. Otherwise, my
> > testing is a huge HUGE waste of time.
> > Ditto for rtems-tools fixes and other repos. If you fix something, bump
> > hashes
> It might be the rtems-kernel that needs to be update ....
> https://git.rtems.org/rtems-source-builder/tree/rtems/config/tools/rtems-kernel-5.cfg
Probably an unrelated failure but sis doesn't build on FreeBSD 12.
I think the RSB needs a bit of attention to ensure the right hashes are
used or
the 100+ hours of computer time it takes for a sweep is wasted.
I will pause from starting the next sweep until a few errors are explained
and
thought to be corrected.
--joel
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/04ea88cf/attachment.html>
