sis broken on freebsd 12
Mon Apr 6 00:20:20 UTC 2020
Hi
sis fails to build on FreeBSD 12. I. The full log is at
https://lists.rtems.org/pipermail/build/2020-April/012855.html and it fails
for sparc and riscv.
checking for gcc... gcc
checking whether the C compiler works... no
configure: error: in
`/usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/sis-2.21':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: /bin/sh -ex
/usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/do-build
error: building sis-2.21-x86_64-freebsd12.1-1
  See error report: rsb-report-sis-2.21-x86_64-freebsd12.1-1.txt
I will try to investigate over the next few days. But I would
appreciate it Jiri could take a swing at it. It is really all I can do
to review the build logs from 100+ hours of test time across three
computers.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/375d5996/attachment.html>
