sis broken on freebsd 12
Chris Johns
chrisj at rtems.org
Mon Apr 6 00:24:52 UTC 2020
On 2020-04-06 10:20, Joel Sherrill wrote:
> Hi
> sis fails to build on FreeBSD 12. I. The full log is at
> https://lists.rtems.org/pipermail/build/2020-April/012855.html and it
> fails for sparc and riscv.
> checking for gcc... gcc
> checking whether the C compiler works... no
> configure: error: in `/usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/sis-2.21':
> configure: error: C compiler cannot create executables
> See `config.log' for more details
> shell cmd failed: /bin/sh -ex /usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/do-build
> error: building sis-2.21-x86_64-freebsd12.1-1
> See error report: rsb-report-sis-2.21-x86_64-freebsd12.1-1.txt
> I will try to investigate over the next few days. But I would appreciate it Jiri could take a swing at it. It is really all I can do to review the build logs from 100+ hours of test time across three computers.
I am confused, it builds for me ...
ruru bare $ ../source-builder/sb-set-builder --no-install --log=sis.txt
devel/sis
RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
Build Set: devel/sis
config: devel/sis-2-1.cfg
package: sis-2.21-x86_64-freebsd12.1-1
download: https://git.rtems.org/sis/snapshot/sis-2.21.tar.bz2 ->
sources/sis-2.21.tar.bz2
downloading: sources/sis-2.21.tar.bz2 - 289.3kB
building: sis-2.21-x86_64-freebsd12.1-1
sizes: sis-2.21-x86_64-freebsd12.1-1: 2.144MB (installed: 226.492KB)
cleaning: sis-2.21-x86_64-freebsd12.1-1
reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.txt
reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.xml
Build Set: Time 0:00:04.409849
ruru bare $ uname -a
FreeBSD ruru 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
