sis broken on freebsd 12
Joel Sherrill
joel at rtems.org
Mon Apr 6 00:38:32 UTC 2020
On Sun, Apr 5, 2020 at 7:25 PM Chris Johns <chrisj at rtems.org> wrote:
> On 2020-04-06 10:20, Joel Sherrill wrote:
> > Hi
> > sis fails to build on FreeBSD 12. I. The full log is at
> > https://lists.rtems.org/pipermail/build/2020-April/012855.html and it
> > fails for sparc and riscv.
> > checking for gcc... gcc
> > checking whether the C compiler works... no
> > configure: error: in
> `/usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/sis-2.21':
> > configure: error: C compiler cannot create executables
> > See `config.log' for more details
> > shell cmd failed: /bin/sh -ex
> /usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/do-build
> > error: building sis-2.21-x86_64-freebsd12.1-1
> > See error report: rsb-report-sis-2.21-x86_64-freebsd12.1-1.txt
> > I will try to investigate over the next few days. But I would appreciate
> it Jiri could take a swing at it. It is really all I can do to review the
> build logs from 100+ hours of test time across three computers.
> I am confused, it builds for me ...
> ruru bare $ ../source-builder/sb-set-builder --no-install --log=sis.txt
> devel/sis
> RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
> Build Set: devel/sis
> config: devel/sis-2-1.cfg
> package: sis-2.21-x86_64-freebsd12.1-1
> download: https://git.rtems.org/sis/snapshot/sis-2.21.tar.bz2 ->
> sources/sis-2.21.tar.bz2
> downloading: sources/sis-2.21.tar.bz2 - 289.3kB
> building: sis-2.21-x86_64-freebsd12.1-1
> sizes: sis-2.21-x86_64-freebsd12.1-1: 2.144MB (installed: 226.492KB)
> cleaning: sis-2.21-x86_64-freebsd12.1-1
> reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.txt
> reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.xml
> Build Set: Time 0:00:04.409849
> ruru bare $ uname -a
> FreeBSD ruru 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
>From config.log:
configure:3033: checking whether the C compiler works
configure:3055: gcc -O2 -pipe -fbracket-depth=1024
-I/usr/home/joel/rtems-cron-5
/rtems-source-builder/rtems/build/tmp/sb-1002/5/rtems-sparc/home/joel/rtems-cron
-5/tools/5/include conftest.c >&5
gcc: error: unrecognized command line option '-fbracket-depth=1024'
configure:3059: $? = 1
$ gcc --version
gcc (FreeBSD Ports Collection) 9.2.0
Copyright (C) 2019 Free Software Foundation, Inc.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/ae756a79/attachment.html>
